3ll3d00d
- Joined
- Aug 31, 2019
- Messages
- 505
- Likes
- 367
Seems a reasonable approach if that's the extension/output you needI was posting about the sub build in DIY Audio and someone kindly modelled the sub for me:
With regards to the alignment, should I be trying to align the subwoofer with one speaker, both or some kind of middle average?
You may have done this already but unless you listen at v low levels, you really need to model the effect of that on excursion.I've measure the subwoofer near-field (1cm), flattened the response with a shelf and added a PEQ to boost the low end.
That looks OK, usually the ASR "standard" is to have the left scale with a 50 dB range and 1 db increments, your scaling makes it look "better" than it is.
Regarding timing and testing your integration I understand how hard and confusing it can be. I would try several of the methods given and see if they "agree" and if not why.
For "sub integration listening tests" I like to use the "Neuman's Kick Drum Train" file which is attached. You can play with the delays and hear differences... a good "kick drum" sound is a good test for subs and their integration. It might also show other issues like "bottoming out drivers" and "clipping" caused by DSP which if you see something unexpected you would want to investigate.
Scale looks correct. How does it sound to you?
There is a thread on subwoofer localization. https://www.audiosciencereview.com/forum/index.php?threads/locating-bass-80hz.66617/ Bass location is apparently FAR from settled science which leads to some "interesting" commentsHowever, I keep thinking I can sense the bass from the direction of the subwoofer but I’m not sure if thats just my bias. Maybe the delays are not right and I’m getting the low bass from the sub before the main speaker bass.
Thanks.There is a thread on subwoofer localization. https://www.audiosciencereview.com/forum/index.php?threads/locating-bass-80hz.66617/ Bass location is apparently FAR from settled science which leads to some "interesting" comments
What crossover frequency/ slope are you using?
It would not surprize me that you can locate the sub... it's not the 80 Hz but at only 12 dB per Octave you are only down 12 dB at 160 Hz and anything over 120 Hz is usually pretty easy to locate. Why did you chose 12 dB per Octave? You probably will need to "reverse polarity" of the sub to get it in phase. I would try 24 dB and 48 dB and see what happens, at least they are "phase coherent". You should actually be looking at "Acoustic" slopes not electrical ones and I don't know what the roll off of the sub and mains looks like at 80 Hz but you may need to take that into account when setting up your sub crossover.Thanks.
Crossover is 80hz, L-R 12db
Also, use 1/6 or 1/12 smoothing, not psychoacoustic smoothing. Re: that dip above 10kHz, please make sure it is not a measurement error. Read this.
