Awesome. That is a good spot!I would try this tweak to try to deal with the issues above the intended range
New 12" Full-Range: Fane 12-250TC
the bigger brother of the Fane got a cone treatment / tweak https://www.diyaudio.com/community/threads/how-to-make-a-loudspeaker-sandwich-cone.402917/post-7467924www.diyaudio.com
Seems pretty cheap and easy to do.
Why are you using full range driver as a woofer btw?
cross at the right point for the drivers in use (and obviously use drivers that can meet each other nicely) and implement a competent crossover. If you do this then no problem, if you don't then problem. That's pretty much all there is to it.In any way, XO/EQ around 1 kHz would not be a good idea, it should be avoided as far as possible, as I wrote in my post #85.
Use these from @3ll3d00d With in room measurements you are not going to get meaningfully better.Afternoon all.
I ran through the setup again this afternoon, I EQ'd each driver and applied the crossovers:
I now want to have another go at alignment but my question is, do I remove the crossover filters before hand?
I assume the crossover filters will throw-off the time alignment of 20hz-20khz sweep. Or, do I leave the crossover filters in place and only run short sweeps on each driver i.e. 100hz-1khz on woofer, 1khz-6khz on midrange and 5khz-20khz on tweeter??
My plan was to simply sweep each driver at the same distance with the mic central between the drivers and use the right tweeter as a time reference then eyeball the impulse response to roughly time align.
The first graph looks reasonable and yes tweeter is first followed by mid followed by woofer. You can go down the rabbit hole of "what" exactly to align i.e. first zero crossing, front, peak, etc. (with filters and room effects it can be hard to tell exactly what you are looking at) or you can use the delays given to your previously which will certainly work.Thanks.
I seem to be two steps forward and 3 steps back at the minute..... a couple of questions........ then I'll leave you alone....... for the rest of today....
When viewing an overlayed impulse response, like the one below, all measurements taken with an acoustic time reference and the reference being at 0ms, am I wrong in assuming that the tweeter is the earliest response i.e closest to 0ms, then the midrange and then the woofer. So, both the midrange and tweeter should be delayed to align with the woofer?
Secondly, this afternoon I took 2 sweeps of the tweeter and applied a 10ms delay between them, however, when I view the sweeps in the impulse overlay they perfectly align. I was expecting there to be an obvious 10ms gap between the impulses, why is this not the case?
What did you build? A sealed DIY sub will generally need some sort of correction to bring up the low end. a pro driver often has a rising response so may need something like a negative high shelf to flatten it while a ported sub commonly needs a protective high pass filter to prevent it unloading below tune.
These are all design Q's though not so much in room issues.
It's rolling off from ~70Hz so what's the goal? ie output level, extensionI used a GRS 12W-4HE driver and built a sealed cabinet, which works out at roughly 42L after subtracting the driver and bracing.
Typically you will add some sort of LT or low shelf here but this needs to modelled along with excursion and power then checked against those design goals.
I just built a sealed sub and agree with @3ll3d00d. Take a nearfield measurement (or much better go outside for a ground plane measurement, In room subwoofer measurements at the LP are useless for speaker design) and bring it into REW and add a low shelf filter, experimenting with different slopes and frequencies, until you get a filter with reasonably flat response. Leave some roll off below 40 Hz as you will get some room gain. That should get you a reasonable starting point for further integration.I used a GRS 12W-4HE driver and built a sealed cabinet, which works out at roughly 42L after subtracting the driver and bracing.
I essentially agree with you. The advanced software tools, including REW, not always give you true and precise measurement results and tuning directions/suggestions, especially in time-alignment between sub-woofer(s) and main SPs at your listening position, as you @levimax wrote in your post #167 that "REW alignment tool does not work for LF / Woofers or sub woofers (works fine for Mid to Tweeter)."Getting the timing right with in-room measurements is always hard.
