Can anyone explain to me if a lower RMS-peak power ratio effect compression?
BIDTheGreat
Hi, all.
I own an Audioengine A2+ and a Audioengine HD5.
On peak-power bursts (like orchestra hits; 7th Guest soundtrack "Short Intro") sound compressed or un-dynamic.
I put this down to the following ratio:
A2+ = 30 watts RMS vs 60 Watts peak [100% more]
Hd5 = 100 Watts RMS vs 150 peak [50% more]
Would limiting the amp to only 50% of RMS power effect dynamics, bursts and/or make it sound a bit compressed?
Compression could be caused by the Amp, the limiter circuit, and the driver itself.
Without looking into this more, attributing the lack of dynamics to the Amp, or the ratio of rated RMS vs Peak power, is ill-considered.
The RMS/peak rating is not the cause - that ratio is just the amp's burst capability. Compression on orchestral hits is the DSP limiter (or the supply sagging) protecting the driver, and small boxes like these limit hard on low-frequency peaks. Running at 50% of RMS only moves you further from the ceiling; it does not change where the limiter engages. Confirm with a sweep: if the output flattens above a certain level, it is the limiter, not the recording.
How are you driving the speakers? I.e. Bluetooth, analogue, or optical/digital?
