Galliardist
I'm aware of all this. If you haven't seen my earlier posts, I dropped vinyl fairly late, 2006. I didn't digitise anything of mine on the way out for obvious reasons.Again not an argument over vinyl v CD/streaming BUT to get the best from a vinyl system you must have as near to silence from a t/t. The Japanese d/d t/ts did just this The Kenwood KD/KP series (among others) did just this - wow/flutter 0.02% WRMS - rumble -80dB weighted. These decks came with an excellent gimbal arm that was a doddle to set up. My first experience of d/d t/ts came when I bought a s/hand Technics SL120 that came with a 3009 d/headshell set up at the SME factory in Steyning. This was a shock after using an AR and then Rega 3 t/ts - the silence was literally shocking so much detail had been lost with the belt drive decks.
So many comment about the 'pops and clicks' from vinyl - really! they should have looked after the vinyl better. I'm going to buy a Lapwing to make digital copies of my vinyl and I know it comes with good software to eliminate the problem, it's just that most of my vinyl simply doesn't have this problem.
My reason to digitise, simple, easier to maintain and operate a digital system.
I listen and listened then to a lot of solo classical guitar, lute, renaissance keyboard music. There is nowhere to hide with vinyl with those types of music, none of the masking that is accounted for in weighted figures. In fact my experience was the other way round - belt drives often had better unweighted noise figures back in the 1980s as I recall, until you hit astronomically expensive decks. I had no way to the silence you refer to, because... it isn't there. Never really was, isn't today. The rumble filter was my friend for some years.
I travelled a hundred miles by train on several occasions to get to a dealer that not only had a Keith Monks cleaner but knew how to use it, for the worse used discs that I bought.
And as for quiet LPs? At times, when vinyl was being heavily recycled, they could become a rarity. Didn't you have to live with noise sometimes? One of the worst part of owning vinyl, when it came down to it, was the constant returning LPs to shops and becoming a "difficult customer" in the process. I hated that bit.
The only wonder for me is how I lived with vinyl for so long. Then again, I'm now becoming reacquainted with some of the music from the record library that I couldn't buy at the time, which I would absolutely have missed out on if I'd gone CD on day one.
I am an advocate for any route that maximises the amount of music available to a listener, and being adventurous in listening.
