- Joined
- May 26, 2021
- Messages
- 511
- Likes
- 804
I have used the word 'again' because I keep getting the same questions, as if people have reacting rather than reading along. None of what you say above though is any sort of counter to what I've said so far except the emphatic 'No'. I take your comments here in abeyance as I can't make sense of them; guessing that an aggressive auto-correct messed with your post.No!
As I recall, when the CD RedBook was introduced at 16bit/44.1kHz, it was not the 'best' for audio reproduction but it was what the capabilities of the technology was at that era.
Please recall that the some of the first CD pressings were not even 16bit-depth due to technology shortcomings.
The RedBook could have easily made the standard to be 24bit @ much higher sampling rates (re:44.1kHz << Nyquist) and then blame the recording/playback hardware (manufacturers) for not being able to produce DACs which did not exist to be able to encode/decode data.
I am fully aware of the 5TimeConstants required to charge to 98% but saying the word "again" four more times does not make anything to be a fact.
Huh?? Sorry, but this post makes no sense. The RIAA curve exists to minimize surface noise and to limit excursion of a constant velocity cutter head system. The media has bandwidth well beyond that of human hearing and this is true of both record and playback. This has already been covered.The media has a major problem with storing the entire audible frequency range hence the RIAA eq. The pre-emphasis introduced in the cutting wouldn't sound so great would it? That alone makes the media storage imperfect not taking into consideration the playback which is the basis of your argument. So as it sits in it's quiescent form might be "low noise" but who care about noise when all you hear is treble?
That would be lovely!Any chance you could run some? None of us have access to the same discs you're talking about.
What would be needed is cutting a silent groove on a lacquer, showing its spectra, and then cutting an LP in the same fashion and showing that spectra, likely from a test press. A test pressing requires shipment to a pressing house and then however many tests made from the initial stamper. You can see that might be a bit of a trick- I don't do pressings- we ship to a pressing house for that. Lacquers are a bit trickier these days- the only source worldwide now is a single guy in his 80s in Japan who makes them out of his garage, since Apollodisc burned to the ground three years ago and there's no sign they are going to rebuild. Its been getting a lot harder to get lacquers as a result!! Most of the LPs you're seeing these days are done on Neumann and similar machines that have cutters that can handle lots of power so they can do direct metal mastering. Older machines like mine are slowing going the way, tied to the fate of a single manufacturer overseas. So no way will I being wasting a lacquer on this account- once you set the cutter head down, its not coming back up until the side is complete!
