MattHooper
- Joined
- Jan 27, 2019
- Messages
- 11,180
- Likes
- 19,864
This seems evident and straightforward to me as well.
That's because you can deal with nuance.
I don't doubt this when it comes to gear playing back the same source. When it comes to different sources being played back on the same downstream gear it am not sure how blind preferences work. With vinyl recording and playback there is a lot going on and as a source and it is going to be different than a digital version. I have dozens of tracks of needle drops of original LP's and the original CD or Streaming version of the same song. I have been listening to them level matched recently and I usually have little trouble telling them apart. When it come to preference though it is not so simple. I am convinced that @beagleman comment about out of phase noise adding width to the sound stage of LP's is generally true. I also think it is generally true for older original LP's that they have a more "mid-range" focused FR balance compared to digital versions. Unfortunately it is also true that when many older analogue recording were transferred to digital they screwed around with the FR to make quick impression that they were better and different but often times these fall flat after a little time listening. For me my preferences were not consistent by format and change based on my mood as much as anything. The only consistent thing I found about my preferences was that the fancy Audiophile remasters like DCC and AP by SH and the like are almost always preferred by me whether digital or vinyl which is a bummer as these are expensive and not readily available. These source difference involve a lot of complicated things ... out of phase noise, FR changes, different master tape sources, etc. so I am not sure if you measured the differences between different sources of the same song that it would give you any predictive value on preferences.Put the same people in a room with unknown gear A and B, which definitely have sufficient difference to be easily detectable, and compare their assessments sighted vs controlled, and their sighted choices will be consistent with their cognitive biases, and their controlled listening choices will be consistent with what the measurements tell us they would likely choose.
Exactly. Although some vinylphiles are looking for the cartridge with the flattest frequency response and the least amount of distortion, many vinylphiles are paying big bucks for a specific sonic signature, like that of a Lyra for instance.Most of the people I know can easily pick out FR changes in excess of 1dB from the midrange of a cartridge. A Lyra Kleos is +2dB from 4k to 10k, and +4 dB at 20k. That is so substantial that I doubt many people wouldn't pick up on it when contrasts with a flat cartridge. Not to say that they'd describe it correctly - this is where terms like "detailed" and "air" come from.
I used to use a Rega Exact cartridge, which was mounted with Rega's own alignment (something like Stevenson), including the third mounting screw. I then aligned it to Baerwald, recorded before and after, and I thought the Baerwald alignment was a bit brighter, but I actually thought I was just imagining it, which is why I did this ABX test, which was one of the earliest ABX tests I ever did:Just do the blind tests, and show me the consistency with sighted.
It's definitely also my impression that especially reissues of albums from the 60s and 70s reissued on CD in the 80s and early 90s had the treble substantially boosted, and I've had this verified by checking it in Voxengo's plugin CurveEQ.I also think it is generally true for older original LP's that they have a more "mid-range" focused FR balance compared to digital versions. Unfortunately it is also true that when many older analogue recording were transferred to digital they screwed around with the FR to make quick impression that they were better and different but often times these fall flat after a little time listening.
Impeccable logic.That is, you can get better sound quality from a cheap vinyl system than a similarly priced digital system.
I addition, the more money you throw at a vinyl system, the more those records will reward you. There is no upper limit because analogue has no sonic limit.
Are you being serious?Here's the truth for you:
TURNTABLE BUYER'S GUIDE: RAW BEGINNERS!
Looking to buy a turntable for yourself or loved one? Haven’t got a clue how to go about it? Paul Rigby presents his top turntable buyer’s guide plus some extra advice Fashion. It can be a right pain in the neck, can’t it? As soon as something moves into ‘vogue’, everyone has to have one...theaudiophileman.com
Impeccable logic.
This is the type of BS that drives @Sal1950 crazy and I don't like it either.Here's the truth for you:
Impeccable logic.
Granted, there is some cognitive bias to it, as in "all the experts say that Lyra carts are the very best, so I have to buy one", but I have also seen reports of people buying Lyra and then selling them again shortly after because that sound was only fitting for certain records (usually older records with less top-octave content).
It seems to me that people audition many different cartridges and then in the end choose one that sounds "just right", meaning it has the specific sonic signature that they're looking for, and often that means a very non-linear frequency response - some swear by a massive spike/rise around 10-15 kHz, others swear by Grado's "warm" drop-off frequency reponse.
This was actually my process as well. I auditioned around 35 cartridges, although most was downloads of recordings. Then I tried to find the one that was the most linear by comparing to CDs, and I settled on a Goldring Elite, although it's not quite linear. After a while and several more auditions I changed it to an Audio Technica AT33PTG, as that was really that sensation of relief somehow: "Aaaaah! This sounds just right".
I do think the Goldring also had a lot more distortion though, and although I usually don't find distortion (very) audible, in this particular case I think it might have been what was grating on my ears.
www.audiosciencereview.com
Possibly in some other universe. Maybe the disc-world universe where science is replaced with magic.Impeccable logic.
Feel free to criticize vinyl; just don't add any ad hominem insults to those who prefer it. It's only a hobby, for crum's sake, not a national defense issue.As long as your turntable isn’t banished to another room, you’re good.
Reproduction from both vinyl and digital sources is imperfect. We can identify more imperfections and greater magnitudes of same wrt vinyl. I don’t possess any of the latter but in my astonishingly limited experience listening to some (blind) digital vs vinyl needle drops I’ve identified subtly different sonics that I can imagine some preferring as euphonic. Even if those people aren’t me. Among all the other reasons.
As @levimax just said, sometimes the pejoratives and aspersions are laid on a bit too thick.
That’s good to know.Based on @Leporello 's previous comments, no.
5. Hipster appeal...Reasons for vinyl in this modern world
1. Full size artwork. Anyone see Squaring the Circle (The Story of Hipgnosis)? The art and packaging can’t be replicated in digital.
2. Some works just aren’t available digitally
3. Special releases and box sets (see 1 and 2)
4. Nostalgia
I gave away 90% of my “records” over the past few years, the rest are in climate controlled storage. Most CDs gone as well. What I have is either irreplaceable, was never released digitally or I have sentimental reasons to hold onto. My dad bought me my first stereo in middle school and I still have my first album that I purchased after saving my 50 cent/week allowance - Cosmo’s Factory. Sound quality, fidelity, etc. plays no part for me.
I'm finding this to be true in my system right now. Analogue and digital are battling for my attention and I can't choose. But one side was very expensive and the other not so much. I'm getting incredible detail out of vinyl and warmth and smoothness out of digital. My new DAC, SMSL D-6, does DSD Direct and that sounds like master tape to me. Like vinyl on a posh table, but without surface noise, which is very sweet indeed.I remember reading somewhere decades ago, from some prominent audio writer, something to the effect of:
The better Analog playback gets, the more it sounds like digital.
Meaning to me, that analog is flawed to some degree, and only has a "Sound" based on its flaws.
When you remove the distortions, overload, noise, mistracking, and on and on, You have Digital.
