Can an in-room measurement predict what sound is direct vs reflected?
spacevector
Bayrea
Are there any in-room measurements and post calculations that can predict the ratio of direct vs reflected sound in said-room across the frequency band?
Lets assume that anechoic measurements like what is published here are available.
My Opinion:
Not "predicting", but via in-my-room measurement:
Stretch out an Impulse, or use ETC, is what I think of.
It doesn't tell you frequency, but seems to indicate energy over time.
Here's a wide dispersion (black) vs narrow dispersion (red) impulse response over 40ms, I interpret the display as level relative to the level of the direct sound...
This is vertically a linear display, like voltage...
And the same data using the ETC display, using decibels relative to the direct sound, also over 40ms.
Just grabbing a recent example. You have the blue line showing the early reflections which were calculated from the anechoic directivity measurements.
You also get the estimated in room response taking into account important room reflections. Like below. The catch being it isn't your room, but a standardized representative room. If you had the needed info you could take the spin-o-rama data and do calculations using your own room. I don't know how to do it myself right off hand, but it certainly would be doable.
Well, what you do is window first the direct sound of your room measurement so usually the first few ms and then make a new window from that time point till the usual 500ms. If you divide both you can have also the ratio of them. This doesn't really work in the bass region though as the first window is usually too short for it.
It's an interesting question. If you have the frequency response of the speaker measured under anechoic conditions at a given voltage, a simple way would be to:
  1. Scale this anechoic response to the distance at which you intend to take your in-room measurement (e.g. if the anechoic measurement was taken at 1m and your in-room measurement will be at 2m, scale the anechoic response down by a factor of 2, ie 6dB).
  2. Take an in-room measurement at said location at the same voltage as the anechoic measurement was taken.
  3. Use a "calculator" tool like the one in VituixCAD to divide the measured in-room frequency response by the scaled anechoic frequency response.
The quotient this generates will be the difference in SPL vs frequency.
I haven't attempted the above with in-room vs anechoic FRs, but I've used it to calculate the SPL difference vs frequency for a driver measured at two different drive voltages.
Here's an example of how that looks (NB: disregard data below 100Hz in this partcular case):
PS: for an in-room measurement, you'd probably want to smooth the measured in-room FR heavily, or average FRs measured at a number of different locations around the listening position, to mitigate the effects of comb-filtering caused by reflections in the room.
My Opinion:
So are you saying that look at the impulse response measured in room and subtract the (known) anechoic response from it. The remainder is room reflection? I may be making some leaps here so sorry if I misinterpret what you are saying.
This only works if all boundaries are further away from the speaker than the LP, right?
Is VituixCAD smart enough to not just simply divide the dB values? I am thinking we need to subtract instead?
So the difference you measured was due to some compression effects? Ideally, if only voltage is changed, the difference would be a straight line (constant bias)?
I've been using PEQ for many years with good results, I use a "less is more" approach and do the bare minimum needed to correct problems in my speakers. I just got a new receiver that has Audyssey XT32 and ran the room correction and not too surprisingly the target flat curve made my speakers sound too bright and harsh, as many people have mentioned. I do think a room correction software could differentiate between direct and reflected sounds and do a much better job than the current ones do. It would basically take the first sounds heard and classify them as the "direct sound" then maybe 15-30 ms later those sounds would be the early reflections. I would rather these room correction softwares just give us more control over exactly what is being corrected so that those of us who know what we want can do it and those who don't care can just take the default.
I may have misinterpreted your original question, given the other answers received.
"Can an in-room measurement predict what sound is direct vs reflected?"
I don't have anechoic measures with which to compare or predict.
If I measure the in-room, I'll just find ways in REW to "look" at what is direct vs reflected.
Using the output of the preamp as an "anechoic ideal" with which to compare is something I'm looking at.
You can easily separate the direct vs reflected when you shout into a large reflective enclosusre "HELLO....HELLO....HELLO...."
REW can assist looking at much smaller enclosures.
I'm more of a practical or experimental than theoretical amateur audio scientist (if I may be so bold as to call myself one)
Example:
Preamp output vs in-room. I didn't expect the curve for the preamp, but I suppose that shows some limits for what could be seen with a speaker measured anechoically - like comparing the drive signal to the in-room result.
@spacevector so are you wishing to measure your in room response and separate out the part from reflections or are you wishing to take the data from Amir's reviews and calculate what your room will do to the result? My apologies for not understanding which it is you are wanting to do.
If I understood yor question correctly you can take a guess looking at PIR spinorama response, as PIR is a mix of direct and reflected sound.
If anechoic measurements are not available than your chances are pretty much none as gating the in-room measurement won't give accurate result for the entire frequency range.
Yes, this is correct. My intention is to measure the in-room response of the speaker as placed in the room, at the LP (or MP, measurement position). Then use post-processing to determine whats coming from the speaker (anechoic response) and what is the room.
Don't ask why I want to do this - just a thought that occurred to me last night (I had had a couple nips). Seems an interesting problem though and may inform some things like room-placement and room-treatment optimization.
Example:
In that example you posted, what is the signal that leads to the blue (pre-amp) ETC like that? Is it an impulse? Also, I am not fully familiar with what ETC signifies - cribbing now.
https://www.roomeqwizard.com/help/help_en-GB/html/impulseresponse.html
https://www.roomeqwizard.com/help/help_en-GB/html/graph_impulse.html
I will guess it has something to do with Fourier Transform results near a frequency of 0Hz.
@JohnPM will know, it's his software.
Expanding the ETC trace shown above to the left:
red - speakers
black - preamp out via 25ft cheap cable and PC on-board ADC
The decibel is a ratio, hence it must be divided ;)
Compression and other causes of nonlinearity, yes.
I'm sorry, misunderstood part of your question yet again...
Both speakers and preamp are excited using the REW Swept Sine measurement signal.
REW "listens" to the results of the sweep and calculates all the displays it has available.
The preamp measures are with no EQ - flat 2Hz to 24kHz.
The speaker measures include EQ, and the sweep was from 10Hz to 24kHz, but the idea of using EQ is to correct their output and room contribution to approximate a flat signal.
Ok, so here is the answer though not a convenient one. Take your speaker outdoors, and measure where there are no nearby reflections. Even then, not perfect and there will be noise, but close to anechoic. Take it back inside and remeasure. Subtract one from the other and the difference is the room reflections.
The Klippel unit essentially does what you are asking, and you see how much it costs. So its possible, it isn't easy or cheap at this time.
Next best is to measure your speaker rather close say at 1.5 meters maybe you can even get closer. Then measure at the listening position. Room reflections are the difference even though there are reduced reflections included in the closer measure.
So if anechoic data is already available - like from speaker reviews here, then all I need to do is take in-room measurement, scale it so that its at similar distance and voltage level like @andreasmaaan outlined and subtract one from other. The difference is room.
Wouldn't the difference would also include the speaker and microphone locations in the room?
I guess I'm not sure what you really seek.
I assumed that's what @spacevector was interested in. After all, how could an in-room measurement be taken that wasn't mic/speaker location-dependent?
