KenA
If you stick them in your ears they probably would.Theoretically can a fuse affect the sound quality ?
For example :
For example :
www.audiosciencereview.com
It was just a joke!Here?
Was wondering whose posts you were reading "here"It was just a joke!
Proper placement is in one's anal opening.If you stick them in your ears they probably would.
I'm more for twisting and wringing it...View attachment 380449
Why does this strike me as ridiculous?
If, after doing so, neither direction resulted in an immediate improvement, I would also strongly recommend trying it at right angles to the original direction of insertion.
Maybe you have a short fuse?Why does this strike me as ridiculous?
After 17 amps the cheese reverts back to Milk
You forgot the ever so important "I felt like a veil had been lifted"... Like a wet blanket had been in front of the speaker and suddenly it was gone...Look sceptics may scoff at this, but I swear by the transformative power of these magic audiophile marvels. Music comes alive with a newfound vibrancy... highs sparkle, mids resonate and lows rumble with depth. It’s as if the performers themselves are in my living room.
In the pursuit of sonic perfection surely cost is trivial to those who understand? You're missing out as these fuses aren’t just upgrades, they’re gateways to audio nirvana. /s
JSmith
True... maybe I should also have mentioned the difference can be heard from the kitchen too.You forgot the ever so important "I felt like a veil had been lifted"... Like a wet blanket had been in front of the speaker and suddenly it was gone...
Only by the wife, tho....True... maybe I should also have mentioned the difference can be heard from the kitchen too.
JSmith
We get you. Whatever the AC mains does the signal path gets but it is in what quantity that matters. It has to be a huge quantity of distorted and non-standard AC mains voltage to get the signal path to be a subject of AC mains induced distortions and SINAD etc.I believe it should not affect the sound because the fuse is situated before power supply in the electrical path.
I would like point out that I intentionally use "electrical path" instead of "signal path", because there is no audio signal going trough the fuse.
Exaitías aftoú tóte aftó. Greek for, "Because of that then this." For your question and assumption that what you wrote is correct and so it correlates with fuses is not a fact and it is a incorrect statement. Fuses when properly specified do not affect the signal in any meaningful way if any way worth even metering or mentioning. But it's a fun idea to toss around if one has spare time... LoL.If what I just wrote is 100% correct, I do not know, since I am not an expert on the topic. Perhaps there is some combination of factors where fuses affect the sound.
In other words...you got to let the fuse have some burn-in time
haha...I meant the fuse should be burn-out”99% Silver + 1% Gold = 100% Sound - more speed, dynamics, clarity, better 3D !”
Hi-Fi Tuning Supreme 3 Audiophile Fuse
Hi-Fi Tuning Supreme 3 Fuses 5 x 20mm F (Fast Blow) Available in the following ratings 250mA, 315mA, 400mA, 500mA, 630mA, 800mA 1.0A, 1.6A, 2.0A, 2.5A, 3.0A, 3.15A, 4.0A, 5.0A, 6.3A (If you require a larger or different rating then the ones listed please contact us) Hi-Fi Tuning of...www.analogueseduction.net
Burn-in is essential, but burn-out should be avoided.
