IAtaman
- Joined
- Mar 29, 2021
- Messages
- 2,520
- Likes
- 4,597
Edit : Check out the new version of CamillaNode here.
Hey All,
TL;DR: camillaNode is an open source, free to use CamillaDSP control interface specifically built to function as a parametric EQ with AutoEQ integration, and is available on GitHub via the link here.
I was looking for alternative UI to control CamillaDSP as a simple equalizer for various headphones I use during the day, and started an investigation to find out what are my options. That investigation turned into a small project to develop an interface that works as a basic PEQ with AutoEQ integration, called CamillaNode, which is available on GitHub for anyone interested.
CamillaNode can run on the same device that runs CamillaDSP, or you can run it from your other PC/Mac/Linux machine to control the DSP running on another machine.
If offers the basic functionality to add/remove bands, change frequency, gain and Q to your liking; save EQ configs to be loaded later on, and download EQ settings from AutoEQ repo on GitHub automatically. There are a few more quality of life improvement functionalities available, like changing color scheme, keyboard shortcuts for switching between EQ settings etc.
Install and basic usage instructions are available on GitHub.
I have CamillaDSP and CamillaNode running on a tiny Rock Pi S with USB input from the computer and USB output to the DAC, which replaced all EQ software I use on Mac and PC. I don't have to maintain different EQ settings across different devices, I don't have to deal with different UIs etc. so has been working really well for me, hope it will be useful to some of you as well.
Any comments, questions, remarks, suggestions are much welcomed.
Here are some screenshots to spice up your interest
Hey All,
