CamillaDSP 2.1: multichannel DAC and safe volume control
alsak0de
Hello everyone. This is my first post, so please bear with me if this has already been discussed. I have read quite a few related threads but have not found one addressing exactly the same concern. If there is one, I would appreciate a link.
I have spent some time using REW to integrate my main speakers and subwoofer, measuring them both independently and together. CamillaDSP handles room correction and bass adjustment, and I am quite pleased with the results so far.
However, the current implementation is still fundamentally stereo: the subwoofer signal is derived from the corrected stereo signal and low-pass filtered, while the main speakers run full-range. Measurements suggest that their natural roll-off complements the subwoofer reasonably well through the crossover region.
My next step would be to implement a proper DSP crossover, producing three independent output channels: left, right and mono subwoofer. This raises two related issues:
  1. Finding a suitable multichannel DAC or USB audio interface.
  2. Controlling the volume of all three analogue channels safely and simultaneously.
Interfaces such as the Focusrite Scarlett 4i4 or MOTU M4 appear suitable for the first part. CamillaDSP can send four independent channels to them over USB, all using the same clock. However, their physical monitor knobs control only outputs 1–2, while outputs 3–4 remain under software control.
I considered replacing CamillaDSP with a miniDSP unit, but I would prefer to retain the flexibility of CamillaDSP and add downstream analogue volume control. My planned power amplifier is a Hypex NCoreX unit without its own volume control, and I am not entirely comfortable relying exclusively on software volume when connecting a DAC directly to a power amplifier.
Surprisingly, I have found very few simple preamplifiers capable of controlling three or four channels together. The apparent alternatives are mainly professional monitor controllers/audio interfaces, AV processors, or expensive and sometimes discontinued multichannel preamplifiers.
I already own an Audiophonics AP310 stereo preamplifier and particularly like its relay-switched resistor-ladder volume control. Since this is partly an experimental/workshop system, I am considering modifying it by adding a third attenuation channel controlled by the existing volume logic. I have looked into the implementation and believe it should be feasible. The left and right channels would feed the power amplifier, while the third channel would feed the active subwoofer.
A less ambitious alternative would be to manage normal listening volume in CamillaDSP while adding fixed passive attenuation downstream. This would establish a safe maximum level in case the computer, PipeWire, CamillaDSP or the audio interface ever returned unexpectedly to 0 dBFS.
My questions are:
  1. Am I overengineering the separation of the subwoofer channel? My measurements suggest that independent crossover filters, delay and phase adjustment could improve the main/sub integration, although I understand that convolution or EQ cannot magically correct deep room nulls.
  2. Does anyone know of a simple three- or four-channel analogue preamplifier or monitor controller with one physical volume control acting on every channel?
  3. Would you be comfortable using CamillaDSP for master volume control when feeding power amplifiers directly, provided that fixed attenuation or another hard maximum-output safeguard were added?
  4. Is there another straightforward architecture I am overlooking?
Thanks in advance for any thoughts or experience.
With high SQ gear downstream, there is no problem putting the ad-hoc User Volume control upstream of the crossovers.
This is what OG "preamps" are for, along with allowing switching source devices. Often now included in streaming devices, see Wiim Ultra for example.
Obviously proper gain staging between components is required to maintain the noise floor, level-match bed channels, sub vs main, but those should be "set & forget" like infrastructure DSP as opposed to ad-hoc User tone adjustments, PEQ.
Personally I require old school Loudness Contour automatically scaled with ad-hoc User Volume control so my choices are limited, and multiple devices doing signal processing requires testing as you go.
Hope this helps.
Hope this helps.
Thanks, that helps. I may not have explained the multichannel bit clearly enough, though.
My plan is for CamillaDSP to do the actual crossover and output three separate channels over USB: L, R and mono sub, each with its own filters and delay. So the issue starts after the crossover, where I need three DAC channels and somehow need to control their volume together.
I now understand that you’re suggesting using CamillaDSP as the master volume before the crossover, then setting the gain of everything downstream once and leaving it alone.
What I’m still unsure about is the safety side. The sub has its own level control, but the mains would go into a fixed-gain NCoreX power amp. In that case, would your gain staging include fixed analogue attenuation before the power amp, so that an accidental 0 dB output from the computer couldn’t produce a crazy level?
I’m asking because the WiiM Ultra example made me wonder whether you were thinking of a system that remains stereo, with the sub output generated later.
I was suggesting it would be simpler to do your User Volume level control upstream of the crossovers.
Yes, in fact Wiim Ultra has two output Limiter controls. One does not let output go beyond a Percentage of master user Volume Level maximum, affects all outputs simultaneously including subwoofer outputs
The other restricts Voltage (between 2 Vrms (default), 1 Vrms, 800 mVrms, 500 mVrms, and 200 mVrms) on the main analog Line Out RCA outputs only, sub is locked at a maximum output ceiling of 2.0 Vrms.
> so accidental 0 dB output from the computer couldn’t produce a crazy level?
That would require a Limiter. I've heard that can be done in DSP. I've used them built into hardware, rack mounted pro gear.
That is just for set & forget level matching of that one channel
I've been getting along okay with the old Click & Clack The Tappet Brothers approved technique: Put tape on it!
Odroid C4 / Armbian runs CamillaDSP as a hi/lo crossover. HF outputs to stereo tweeter amp, LF outputs to Crown XLS (bass bins) and pass-through outputs from the Crown to stereo LF amps for the monitor woofers up at ear level. Using the passthroughs is a dirty hack that doesn't merit a "2.2" shorthand but I find it satisfactory. Doing it "right" with a 5th and 6th channel would probably improve a few milliseconds of latency in the LF at great cost.
Volume control is Roon with roon-extension-csdp passing volume changes into the CamillaDSP websocket.
Thanks. I agree it would be simpler, but I still feel it would be more elegant and safer to keep the entire digital chain at a fixed level and use a multichannel analog preamp downstream. Then again, maybe I’m just being stubborn about keeping the channels separate for cleaner bass management.
Thanks for sharing; very interesting pipeline indeed. If I’m understanding it correctly, you’re using the M4 as a four-channel DAC in a fully active two-way stereo setup, rather than for conventional 2.1 bass management. Your CamillaDSP pipeline looks very clean: master volume and tone controls before the 2×4 split, followed by separate crossover, level, and time-alignment processing for each driver section.
Yep. It's a bit unconventional. I initially built it as a stereo two-way active speaker for desktop nearfield. M4 as 4-channel DAC driving L+R big ribbon tweeters and L+R 6" SBAcoustics ceramic woofers. The project had noticeably more bass than the prior speakers, and having realized what I was missing, I set out to add more low-end. The next step up from the M4 was more than 3X the expense; jumping to 8 channels felt extravagant for what was a learning-as-I go low-dollar project. (In retrospect, yes, splashing out upfront on an Okta8 would've been $ well spent)
I tried adding a second USB 2-ch DAC - bad idea; messy alsa configs and clock drift. Maybe I can drive 2 amps off the LF channels? Once I realized pro-audio amps had both an onboard low-pass filter and full-range pass-through outputs, the whole stack came together. I'm low-passing the LF channels again in the Crown - I guess that could count as another set of channels, but they're downsteam of the CamillaDSP and not independently configurable. The Crown drives a old pair of KLH Model 23s - stout 70's era sealed cabs with 10" woofers, and tweeters and passive xo disconnected. I suppose the Crown could be bridged into a single .1 sub channel, but I'm not chasing 16Hz and I like the 6dB (?) bump from running both channels into speakers. I am intentionally ignoring all the details around phase and delay and whatnot; I figure it's all below Schroeder and the room itself is making greater troubles.
Anyway, stack it all up, sweep with REW, follow the OCA inversion & convolution technique to smooth the relationship between the 6" and 10" LF drivers, and hey, that all sounds pretty good and measures not-awful. It's been in daily service for 3 years now with no changes.
You asked about volume controls - having soldered resistive stepped attenuators, and autoformers, and pots, and L-pads and and and... I've given up on analog volume. I love a good variable loudness curve, and CamillaDSP gives it to me. Haven't had any 0dbFS problems to date; the power amps run at around 50% gain setting and do have limiters - I leave them enabled.
