KR500
- Joined
- Nov 18, 2019
- Messages
- 153
- Likes
- 129
Hi ;
I gave our daughter and son in law a pair of these when they came out quite a while ago and are getting them regifted back since they are moving and downsizing.
Anyone have any experience with these speakers ?
I think they were designed by Henry Kloss and originally built in Maine or Massachusetts before offshoring later into plastic budget designs
thanks for any thoughts you might have to share
"The M80 is the top-of-the-line Newton Series bookshelf.
Each MDF enclosure features a beautiful real-wood veneer finish and contains an 8" woofer, a 3 ½" midrange driver and a silk fabric tweeter.
The speakers may be positioned vertically or horizontally.
The versatile M80’s tweeter/mid-range mounting plate can be repositioned, in case you choose to place them horizontally.
The M80’s can also be bi-wired."
Detailed Specs:
SPEAKER TYPE - BOOKSHELF
ENCLOSURE TYPE - BASS REFLEX
CABINET FINISH - SLATE, MAHOGANY, BLONDE MAPLE
FREQUENCY RESPONSE 40Hz - 22kHz
MIN/MAX POWER 10 WATTS / 150 WATTS
SENSITIVITY 86dB
NOMINAL IMPEDANCE 8 OHMS
MAGNETICALLY SHIELDED
TWEETER SIZE ¾"
TWEETER TYPE DOME
TWEETER FERROFLUID COOLING
TWEETER MATERIAL - NATURAL FIBER
MID-RANGE SIZE 3½"
MID-RANGE TYPE CONE
MID-RANGE MATERIAL - INJECTION MOLDED POLYMER
WOOFER SIZE 8"
WOOFER TYPE CONE
WOOFER MATERIAL - INJECTION MOLDED COPOLYMER
CONNECTORS - GOLD-PLATED BINDING POSTS
DIMENSIONS 18"H X 10"W X 10¼"D
WEIGHT 28 LBS. (EACH)
Detailed Specs:
SENSITIVITY 86dB
TWEETER SIZE ¾"
TWEETER TYPE DOME
MID-RANGE SIZE 3½"
MID-RANGE TYPE CONE
WOOFER SIZE 8"
WOOFER TYPE CONE
