Cambridge Audio EXN100 vs Eversolo A8 comparison blind test.
You are quite correct. But somebody is going to think up the "Sub Threshold Intermodulation" marketing ploy. When they do, you read it here first! :)
From what I'm hearing, the soundstage effects clearly seem time dependent as one would expect for creating/sharpening the sense of depth and direction. If it is intermodulation it could combine harmonic cancellation with complimentary harmonic reinforcement. Both plus and minus...
I'm fortunate to have the time to play this way. Quoting Nelson Pass re: an almost heretical design: "Get over it! It's entertainment!" :cool: And for entertainment, try the cleanest DAC master clocks you can find and give them the cleanest power supply you can provide. Get back to me when you do... Cheers!
Don't hold your breath. I'd rather use my time enjoying my - already perfect - music :p
Compared Cambridge Audio EXN100 to Eversolo DMP A8.
OK full disclosure this is not a technical benchtop measurement or review of these machines. If you are looking for that go no further.
Both are attractive with the A8 having a more modern appearance whereas the Cambridge looks more like the VCR sitting just a few feet away.
Setup was easy on both. The A8 comes with a remote. And between that and it's touchscreen things went quickly. However I had to stop it at the third Update. I'm not sure what was going on but it became annoying.
Both machines have a relatively large screen that I would find only useful for setup and if the device stays within arm's reach. A step or two away and they become unusable. The Cambridge has VU meters that can be displayed which are interesting and my wife likes but they are a pale comparison to actual meters and I doubt if they are calibrated. So they're entertainment.
The A8 screen is brighter and sharper but that I'm sure figures into it's lofty price. For me both are wasted as I would never be beside it and what I need can be done from a phone or the A8 remote.
A big pain for some might be turning on the A8 remotely using your phone. There is a "Wake on Lan" feature that did not work. And the A8 must be connected via Ethernet to use that feature. The instructions are prepared for failure is it goes on to say to use the remote if the device fails to turn on. Not a huge issue for me as I have to be at the amplifier to power it on as it also has no remote.
The Cambridge has a less cluttered app. Settings, Audio settings, on/off and sources are all on the home screen. There's a lot going on at the A8 home screen. However in fairness the A8 has more options. I won't go into all that. Amir has done a review on this streamer.
I set up an A/B blind test for both machines. My wife set in one room with the streamers swapping between them as songs played from Tidal via ethernet cables.
I set volumes as best equal. Turning off auto audio tweaking in the apps. Too bad there isn't a Neutral button in these apps that will stop any interferences.
Both were powered via their standard black cord in the box. Although the Eversolo salesman was quite keen on packaging the A8 with a $300 aftermarket power cord. I politely declined. Crutchfield sales never brought up such.
No I didn't open up the chassis and look inside any more than I might dissemble a TV, tool or appliance. They can use popcorn and playskool parts so long as it sounds good (to me).
In the end I found an overwhelming likeness for the Cambridge. It sounded sharper. The cymbals of a jazz piece were clearer and all but one operatic voice sounded fuller. Yes, yes subjective.
It was surprisingly as the Cambridge is described as warmer on the internet and by the salesman. After a long discussion with a Crutchfield salesman (before the A8 arrived) he recommended the Cambridge over other units even costlier ones such as a Hifi Rose RS451 after asking me questions about my music preferences and how I listened. My Crutchfield experience reached the corporate sales level with someone there picking up and carrying the ball when I was improperly transfered.
Just a quick plug for Crutchfield they are top tier. I look first to them for home Audio. Pro audio comes from Sweetwater and Crutchfield pro.
In classical, jazz and all but one opera vocal the Cambridge was chosen. I chose the A8 for one male pop and two female vocals.
Interesting later talking with my wife she found the A8's sound "Shrill" to use her words. Some songs were unpleasantly harsh. Nothing but praise for the Cambridge. Days back she had high praise for the Cambridge over music via the Yamaha receiver pre amp out. The Yamaha is Bluetooth.
The retail prices are close. I got a discounted Cambridge from Crutchfield so it came out $300 below retail. The Eversolo salesman gave a $100 discount.
I had planned to return the Cambridge due to it's inability to play Spotify Lossless but I've since started a Tidal account. Problem solved.
I'll do extended listening to the A8 to see if fatigue sets in. It doesn't with the Cambridge.
Perhaps there's an A8 setting or adjustment that can improve things. Thoughts?
Speaking of such the A8 has a lot of adjustments. There are six DAC filter characteristics choices. I tested it as it came with the "Short delay Sharp Roll-off" set. The XLR/RCA outputs have seven options. It goes on and on. Highly customizable. If flexibility with sources and sound manipulation is a goal I'd definitely recommend the A8. I find the choices something I won't use. I'm looking for a simple clean handling of the signal. Minimal bells and whistles. Not interested in separates. Need Preamp/streamer/DAC. So I'm not going to buy DAC x because it's "a better value" or this one does the same or better for a fraction of the price. Because it likely doesn't.
It's been a lessons in expectations. Researching the Eversolo and having read Amir's review I felt positive about it. During my blind test I was sure that I was picking the A8. Lesson learned. It's about the ears. Each DAC like a voice has a uniqueness. You like it or you don't. Price brings options, a brand name and perhaps nicer build but that guarantees nothing.
I must admit to being a little disappointed. The Eversolo is a sharp looking and feature stocked machine. There is little negatives I can mention. Perhaps if the filters and other variables mattered to me I might have come to different conclusion.
As is I'll be asking for it's RMA.
Trust your ears. In the end that's all that matters regardless of the nay sayers and "experts". Based on reviews and specs alone I would have bought the A8.
I read a post Amir made about measurements being all or nothing. They are neither. But certainly are a good starting point. The goal line is set by your and only your listening pleasure. Don't give that choice to the salesman or anyone else. Unless of course they are willing to buy the equipment for you.
Re read. They were matched. Switching was instantaneous and long. Settings matched as best can be done in my and your home. No mistakes.
Re-read: No. Your methodology was flawed and the test was not “valid”. I don’t see how you could spend much time here and not realize that. But glad you like your DAC. I have a Cambridge and the software is glitch-free and Roon-compatible. which is worth a lot.
No the methodology used here is flawed and antiquated. He did a double blind listening test. Line level matched in two different room. The only thing that changed was the DAC /streamer. At least 5 listeners in the blind listening test could clearly hear the differences between the two. Explain to us exactly why his methodology is flawed and invalid
That we have to keep posting this is an endless source of hilarity.
