Cambridge Audio CXA81 S2 vs Rotel RB 1552 Mkii
yugs
Hi. I would like some advice on an amp, streamer, and speaker combination.
Option 1
Rotel RB 1552 Mkii , Wiim Ultra, B&W 606 S3
Option 2
Cambridge Audio CXA81 S2, Wiim streamer Pro Plus (as transport) , B&W 606 S3
The room area is around 30M2, but it opens into the dining room, so it's not fully closed. My main source of music is Tidal Hi Res. It's mainly for listening to music in stereo and occasionally for home entertainment, so I don't really care if it's not good for the latter.
The price difference between them is negligible.
Neither the Cambridge nor the Rotel look particularly good measurement-wise. Doesn't mean they will sound bad, but for the money you can simply expect more today.
Why not consider a Wiim amp Ultra if you consider a Wiim device in the chain anyway?
I haven't heard the Wiim AMP Ultra but I'm not entirely convinced that it has a better sound stage depth and separation compared to the Cambridge. Which power AMP speaker combo or integrated versions would you recommend in the same price bracket? I'm also open to alternative streamers if there is good value for money out there..
Unless very badly broken, amplifiers with state of the art measurements have no impact on soundstage width or depth.
Amps do not influence the sound stage. All of these amps will likeley sound the same under controlled conditions.
None. Combinations are a myth for amps and speakers, stemming from the early tube days, where the output impedance had a massive impact on the frequency response. Nowadays (the last 50 years or so), that is no longer the case.
As to speakers: look at:
Sort by score (with or without EQ/sub), pick your price bracket, and see which one lands on top that you like the look of. Those are likely good candidates to go and listen to in person. And even then, note that the listening space in the store is not the same as at home. At home, the same speaker may sound quite different because the room is very dominant. My tip: look at KEF and AsciLab.
Hi,
It's hard to look past WiiM for streaming, particularly because of the included room correction/EQ.
Plenty of very good amps out there - check the reviews here. One suggestion: something from the 3e range? Hypex based models are a step up (but not audibly) is you want to spend more.
I'd agree with the previous posts though, WiiM Amp Ultra is a good shout.
I'd also agree about looking at alternative speakers.
Sound stage / separation etc doesn't come from the electronics, its encoded in the recording and altered by your speakers and your room.
Take a while to read some reviews (here) and the comments.
Enjoy :)
You may be convinced if you read the following review based on measured performance:
There is no way the Cambridge Audio integrated amp, or even their separates can match (but very comparable) the performance of the Wiim amp Ultra, except for the higher output (that's only if compared to the CA separates, not the CXA81 integrated, that is only rated 80/120 W 8/4 ohms, so the Wiim Amp still wins).
Wiim Amp still wins
User wins :)
IMHO when electronics is already transparent, convenience of use starts to be important. For me single remote wins over multiple.
User wins :)
100% agreed, both amps are transparent enough. Depending on his listening habits, the class D Wiim may be slightly better for the B&W's impedance dips but it that's just an educated guess.
It really looks way worse than it is because of the 45 kHz bandwidth.
In reality it's more like this:
I have a bunch of 4-star AB amps, a similar power Hypex and two Cambridge integrated. I can definitely tell them apart. Not that I have some crazy auditory memory and can name each one upon hearing, but can say if the selected amp had changed or roughly how many sound signatures are included. The tone tests are essentially a fingerprint.
Exactly how wines don't taste the same, but a chemical profile would show them to be very much alike, despite a universe of variables. This wine tastes better, this one is dry.... or just different. Yes, amps sound different, despite the theories.
Actually, it’s the exactly the other way around.
Do the wine test double blind, and you’ll have a very hard time keeping them apart, but trivially easy to keep them apart chemically. Very similar with the amps.
So yes, in a way it is like wine, just not the way you think it is..
Unless you did that testing blind and level-matched, all you know is what your brain is telling you. Doesn't mean that the expected result ("can tell differences") would turn out in any real, well controlled test. An impression of reality isn't the same as reality itself.
People failed to tell apart the majority of amps 40 years ago (p. 78) - and the amps certainly haven't gotten worse since then.
Yeah, so, bad news about that whole wine tasting thing:
They are ~90% water, 8% alcohol and 2% organic compounds..... 99% the same chemicals, but do they taste the same....?
Amps respond 99% the same on paper, but do they taste the same?
Somewhat of a contradiction. People claim nobody can hear the difference in amps, but then refer to "inaudible" test differences in making their own amp selection.
If you can't hear a differences....let me select your amp. See how you like that.
An amp just needs to be properly able to drive the intended loudspeakers and not produce audible distortion, thats it.
The only times I have heard a difference were because of either or both of the above.
