I have another view. They sent for amir a unit with quality component. Mass product still a same quality?
Of course you do. You would have a computer just like me. And you would have a powered downstream external amplifier. AP is actually better than your situation as its unbalanced inputs are floating.As I understand it, in his setup having the USB connection (regardless of whether USB is being used) completes the loop between the computer, the CXA81, and the AP. Most of us probably won’t have a loop like that.
They offered to send a random sample from one of their retailers. I told them that I trusted them to not hand pick one and send one from factory which they did. So while it is possible there are variations in each unit, I don't consider them trying to game this evaluation.They sent for amir a unit with quality component. Mass product still a same quality?
I don't see a future for this type of product within knowledgeable audio groups such as ASR, especially when compared with a Topping (or SMSL) DAC combined with say a Hypex based power amp. Such a combination will provide SOTA performance with twice the power at half the cost.
I understand a lot of people prefer an attractive simple system, my own preference would be for a DAC with an integrated streamer.There is absolutely a future for this type of product in my opinion. Best audio component would be a 2 channel integrated that would measure SOTA. Not everyone wants a bunch of little boxes that measure perfect on the bench. I see why people buy a Cambridge.
I must say i never understood this hypex hype. I've never heard a nice (not good), nice hyper amp by it's own. They all sound like crap even if they porvide twice as much power for the same price. Unless u put a nice (maybe tube) pre/power amp , which again will add cost. Hence why you would see most expensive Hyper implementations doing so. So if i had to choose between twice more powerfull SOTA lifeless crap , or less powerfull nice sounding OK amp, guess what ?I understand a lot of people prefer an attractive simple system, my own preference would be for a DAC with an integrated streamer.
It's personal preference to some degree, and I was just putting forward a better performing option for those interested in seeing alternatives. The reality is that you are paying for something readily available at half the price, and with more power. The hypex amps with their extra power provide a lot of flexibility with speaker selection, which is more important to me. They run cool and can be placed out of sight, so you will still only see the one box in any case, which can also be controlled by a remote.
IMO the only upside with the Cambridge is for those wishing to connect a turntable and require an analogue input. In that case I would get a secondhand Benchmark DAC 2, which when combined with the hypex amp would be the same money as the Cambridge.
My 2c as they say.
Not a good idea. You wind up giving clean bill of health to a lot of products that have issues. People go and buy them and complain your tests were no good because they don't use such isolation.I would suggest that every class I audio product with USB input should have the USB link galvanically isolated.
I am not sure that you understood what I wrote, as you have used only partial citation of my sentence. I would want for every manufacturer of the class I product with USB input to make this USB input galvanically isolated. I am not talking about your measurements.Not a good idea. You wind up giving clean bill of health to a lot of products that have issues. People go and buy them and complain your tests were no good because they don't use such isolation.
This doesn't mean you blindly measure. I go through quite a few steps to minimize or eliminate ground loops. And AP's floating input helps most of the time (but when it doesn't, you have many alternatives).
Ah OK. I apologize then.I am not sure that you understood what I wrote. I would want for every manufacturer of the class I product with USB input to make this USB input galvanically isolated. I am not talking about your measurements.
My 2c as they say.
I am afraid that any integrated amplifier will be compromised in the "N" part of the THD+N measurements, so the SINAD score will not be great and the product will be underestimated just because of this lower SINAD, here.Would love to see a review on ASR of 2 products. Denon PMA-1600 and the LUXMAN L-505uXII. Think the Denon is in same price family as this controversial Cambridge and just based on common sense probably better than the Cambridge. The Luxman more bucks... but in reach in that category depending on where you look.
It's about the cost and effort. It's just very recently (months) that ready-to-use fully integrated High-Speed USB2.0 Isolator chips are available. Before that everybody had to cook their own design with two FPGA's on either side of the isolation barrier which is crossed with an universal digital isolator chip.I would suggest that every class I audio product with USB input should have the USB link galvanically isolated. There is a zillion of possible component combinations where the non-isolated USB makes an issue. I know several owners of nice Topping DACs like D90 who have audible issues only for the reason of non-isolated USB in the class I DAC. I do not understand why the manufacturers are so careless. It is the manufacturer’s design flaw, no excuses appreciated.
