Cambridge Audio Azur 640C V2 Review (CD Player)
Rate this CD Player
  • Terrible (*)
    Votes: 0 0.0%
  • Mediocre (**)
    Votes: 1 1.3%
  • Good (***)
    Votes: 16 21.1%
  • Excellent (****)
    Votes: 59 77.6%
-3dB is what it takes with many recent masters, especially pop and rock music but would not be enough with some. I’d still go for that, personally.
And we’d need to measure this box to see if it’s otherwise transparent ;)
That would be interesting (to measure the 618) ..
I had a 540C V2.
I’ve just bought a mint Azur 650c for £65 and it sounds marvellous!
I have one of these boxed up in my closet. It stopped reading discs. Maybe I should look into fixing it.
Thank you for this review. Very interesting.
I own a 840C that has (supposedly) better DAC with built-in upsampling circuitry.
It can be used also as DAC thanks to SPDIF/Toslink input.
Do you think you will have the opportunity to test this model as well?
Thank you again!
I have an 840C and am attempting to test it using the @NTTY CD and methodology. It certainly looks good up to now.
Key blurb (from the manual):
  • Anagram Technologies ATFTM (Adaptive Time Filtering) upsampling process... This system intelligently interpolates 16 bit/44.1kHz CD (or other) data to 24bit/384kHz through the use of a 32 bit Analog Devices Black Fin DSP (Digital Signal Processor)
  • The ATF system applies sophisticated polynomial curve fitting interpolation and incorporates a time domain model which allows data buffering and re-clocking almost completely eradicating digital jitter.
  • Because the audio data rate is so high aliasing artefacts are moved way above audible frequencies allowing us to use a low order 2 pole linear-phase Bessel filter on the output for constant group delay and minimal phase shift.
  • Two very high quality Analog Devices AD1955 24 bit DACs are used in dual differential mode.
It also has digital inputs and outputs. The digital outputs can be passthrough or upsampled to 48/96/192 at 16, 20 or 24 bits, with or without dither. Some potential for measurements there!
Note that my interface is set to minimum gain which loses about 6dB in level (if I turn up the pre-ADC gain, I lose SINAD). I guess this is OK as I'm digitizing at 24/192? Also, the Topping E2x2 interface ADC may be a limiting factor with some measurements, Amir found its ADC SINAD to be 110dB and here I'm using it with unbalanced input nominal only 2V. I did measure its ADC SINAD at 106.3dB (20hz to 20khz) under those conditions (using a DAC with an Amir-measured SINAD of 120dB).
The 840C has balanced outputs but I don't have the necessary cable.
Jitter (as per the blurb, it certainly seems to have been eradicated):
Filter:
You get very good results! If you increase the gain of the Topping when measuring the Azur at 0dBFS, what is the resulting THD+N? Same, isn’t it?
But anyways, even so you’re good for CD players measurements, since it’s the max the format is capable of ;)
The THD+N increases by 1.3dB. Looks to be mostly extra 2nd, 3rd and 5th harmonic distortion.
I've fixed it. Being a Linux user, I had to start up a Windows VM and use the Topping control software to apply +5dB digital gain to the interface, leaving the pre-ADC analog gain at minimum. (+6 ran into clipping). The software allows the settings to be loaded into the interface, so continue to apply under Linux.
Nice!
If you plan to test different CD players, you might want to keep some headroom with digital gain (like 4dB, it obviously does not degrade measurements), and adjust the last few dbs with the analog gain, in case it makes a difference.
The inclusion of both an optical and coax output is a nice touch.
Thanks ddaudio, nice job! It seems to perform well considering it is a 12-15 y.o. machine! Just a bit scary the jitter, is the blue "comb" the output of the 840C?
Have you tested also how it performs using a state of the art spdif digital source?
Best
Alessandro
Best
Alessandro
The "blue comb" is the jitter test wave file from the cd imported directly into REW RTA. Since there are no purple spikes visible above the noise floor, I understand this to be a perfect jitter performance by the 840C. Right, @NTTY ?
Not surprising about the pre-emphasis. I had one of their universal disc players of a slightly later vintage and it did not apply de-emphasis either.
My 840C did not have de-emphasis, either. Since pre-emphsis/de-emphasis is part of the Red Book spec, I don't think it's a "proper" CD player if it's not supported.
Yep. You only see the low level analog noise floor on that view. The J-Test is nailed.
Best
Alessandro
It's 21 years old, not 12-15 years old. The V1 was released in 2003and the V2 was released soon after by early 2005.
Hello Everyone,
This is a review and detailed measurements of the Cambridge Audio Azur 640C V2 CD Player and Transport.
The Azur 640C V2 was available from 2008(?) and I don't know until when.
This is a mistake with the dates. It's not from 2008. The Azur 640c V1 was released in 2003 and the Azur 640c V2 was released in 2005. You can see the reviews of the Azur 640c V2 in 2005. https://www.tnt-audio.com/sorgenti/azur640c_e.html
The 640C version 1 was quite different internally.
This is mine after I modded it by replacing the original 'e' core transformer with two toroidals.
Many of these early players were plagued with noisy transformers (mechanical hum) - I bought mine quite cheaply from Richer Sounds (it was a customer return because of the hum).
Not how much more simple the DAC board is compared to the V2!! This uses Sony optics - KSS213C IIRC.
I had this beauties for 15 years or so (CA azur 640A+C):
Then, I had this one for a few months (Cambridge Audio CXC V2):
As well as its partner the CXA (I don't keep any picture, sorry):
So, yes, even I don't have any device from Cambridge Audio now already, I'm still in love with the English brand.
