Peter Verbeek
The cause is that Equalizer APO isn't working. If it did before then a Windows update "broke" Equalizer APO. This is usually fixed by starting its Configurator. This app checks and fixes, if it can, things that got broken.It just doesn't EQ anything. It works (test section, GUI), but it doesn't seem to EQ anything. I am on windows 10.
However, if Equalizer APO isn't work at all, so after installing it and Peace, then it depends on what device you need to EQ. At installation of Equalizer APO it installs itself (activates) only on the default output (speakers/headphones jacks) and input (microphone jack). If you're using a Bluetooth, USB, HDMI, etc. connection then you need to install Equalizer APO on that particular device in the Configurator.
If you have done the above and Equalizer APO still isn't working then you might select "SFX/EFX" (or if not available) "SFX/MFX" in the "Install as" dropdownbox. This is located at the right of the troubleshooting options. These options are coming available after clicking on the device name in the connector column at the left and then checking the troubleshooting options checkbox.
