- Joined
- Jul 7, 2024
- Messages
- 80
- Likes
- 1,048
Hi everyone!
Many of you probably know that I am developing the other models in the Cadentia series. Including a 3-way centre channel model, Cadentia C.
The Cadentia C project started quite a while ago, but has been on hold since I have to prioritise getting the Cadentia 3 into production.
I came back on it this year, but I still haven't quite settled on the design for one reason - I think it's a bit tall
When designing a centre channel commercially back in the companies that I worked for, we usually try to make it as short as possible so it can fit under more people's TVs.
But for the Cadentia C, I am trying to reuse the same mid-range/tweeter waveguide section on the Cadentia 3, to maintain acoustical and aesthetic consistency.
That will put the height at about 26.4 cm
The overall dimensions are 26.4 x 62 x 28 cm, so not too deep at least.
So I just want to seek some opinions here - Will the 26.4 cm height be too tall for your setup, making it a deal breaker?
I appreciate your input.
And here's a bit more spec and info about the Cadentia C:
3-way sealed design
- 1.1 inch TPCD Tweeter
- 4.5 inch TPCD mid-range
- 2 x 6 inch paper woofer
Sensitivity: 88dB/2.83V
Impedance: 4Ohm
Bass extension: -6dB @ 50Hz
Due to production capacity, I would like to transition my focus more toward the finished products in the future, so the kit version of the Cadentia C will be a limited release.
Thank you.
3-way sealed design
Impedance: 4Ohm
Thank you.
