timechaser
- Joined
- Sep 26, 2025
- Messages
- 7
- Likes
- 3
I used to be of the camp that felt "A shiny purple HDMI cable costing $500 must be better than this dull black one which I can get for $10" (I live in Singapore, pricing reflects local reality).
And then I discovered this forum, and after some experimentation, my thought process was changed. I still get attracted by shiny things, but thankfully I don't succumb to them. I got new speakers recently - Q Acoustics M20 HD to replace my busted Ruark Audio MR1 Mk2 to use with my desktop. I know - overkill - but here we can agree to disagree.
The speakers of course come with interconnecting cables and a power cable. All I had to do was plug in a USB A to B cable (Ugreen) and an RCA to a subwoofer. But then the desire to change hit. And here, I have to thank all of you who made it possible for me to save 100s of dollars. I did change all the cables, but based on simple logic - should be prettier than the current cables and the ends should sit flush with my speakers.
So after sourcing parts, putting things together, and buying two (I still don't know how to solder), I ended up with the cables attached.
The speaker cable is a 13awg Supra Jensen Skytech 2.5 (cheapest I could find looking for 14awg approx - the max the manufacturer recommends), prettified and connected to Nakamichi banana plugs. The USB is Lindy (a bit pricier than my Ugreen or other China makes which I could have got, but I decided to splurge). The RCA is a KabelDirect (1x to 2x RCA - the sub connection demands) and lastly the power cable is a modified C7 cable with a right angle connector (to make it sit flush) with the UK plug tweaked with a 2a fuse instead of the customary 13a. The RCA and USB are plugged into the speakers via right angle connectors (the tragedy of signal degradation - oh my!!!!). The flush bits are important as the placement of the speakers (on stands) is such that if things stick out, I need more space from the walls, and that is not approved!
To my eyes, it looks prettier. To my ears, it sounds brilliant. Can I tell the difference between before and after on the sound? No. Do I care - also No (it sounded brilliant even earlier). Am I happy and satisfied with the prettiness and the finish? Absolutely yes!
So thank you again.
Photos for enjoyment
So thank you again.
