Cable Restoration via Tachyon Treatment
Status
Not open for further replies.
klettermann
Coastal Connecticut
As a retiree I enjoy putting my free time to good use. My most recent work has been with cables. See abstract below. The full paper is attached as .PDF. Cheers,
Restorative Tachyon Field Treatment of Legacy High-End Interconnects:
A Controlled Study
@kletterman April 1, 2026
Abstract
This study evaluates the effects of tachyon field treatment on legacy high-end audio interconnects. A pair of nominally identical cables was examined, with one cable subjected to a 72-hour treatment at a Sedona AZ-based facility and the other retained as a control.
Electrical characterization was performed using frequency response (20 Hz–20 kHz), time-domain analysis (energy-time curves), and wideband noise measurements in the digital domain (dBFS). Across all measurement modalities, no differences were observed within the resolution limits of the test system. Frequency response traces were coincident within approximately 0.05 dB, impulse timing and decay behavior were identical, and noise spectra were indistinguishable down to a system noise floor of approximately −135 dBFS.
Extended listening suggested subtle, non-repeatable differences in spatial coherence, decay characteristics, and perceived high-frequency behavior. These observations were not reliably identified under blinded conditions and did not correlate with measurable changes.
Under the conditions of this study, tachyon field treatment did not produce detectable changes in electrical signal transmission characteristics. The divergence between measurement results and informal listening impressions suggests that any potential effects, if present, lie below conventional measurement thresholds or outside the scope of standard linear analysis.
More like
in the realm of psychoacoustics as opposed to physical differences.
Insufficient measurement precision to verify perceived differences is such an audiophool cop-out.
"I've discovered another clean source of Snake Oil!"
That's obvious: tachyons and tachyon fields, depending on their energy output, are subject to a backward motion in time, which leads to causality problems in the sequence of sound reproduction.
This is unlikely to be reproducible and will lead to a different result each time. Furthermore, the effects of effect before cause are unpredictable, especially with such time-critical overtone spectra as those found in music, and inevitably lead to unpredictable and unstable states.
More like
Given the speed of your response I'm guessing that you didn't get to the paper. It goes into this in a bit more detail, and I realize not everyone has time to go through it. Anyway, that said, the null result is actually consistent with what one would expect under a fully equilibrated tachyon field.
In that regime, structural perturbations are not expressed as first-order electrical changes, but rather as higher-order effects—e.g., bathochromic displacement of transient polarization states within a vectorial dielectric framework, or phase-stable temporal chirality at the conductor–dielectric interface. Those effects would not be expected to manifest in conventional R, L, C or linear frequency-domain measurements, particularly once the system has reached field-coherent equilibrium.
So in that sense, the absence of measurable deviation is not evidence of no effect, but of complete field integration. Cheers,
Seriously? You've never seen Star Trek?
This is how educational gaps arise... ;)
Although tachyons were theorized in 1967, I don't believe they were mentioned in the O.G. Star Trek. They were mentioned in Star Trek NG and DS9 which makes them contemporary to The Prince of Darkness (1987).
I image you could fix any group delay issues with a tachyon DSP :)
Before they even happen!
Any Star Trek fan read that thread title and understood in warp 9 speed that it was April's Fool.
Status
