Keith_W
I have an 8 channel system with the DAC positioned about 5m away from the amplifiers. I therefore have at least 8 long interconnect cables that runs from the rack to the amps which are next to the speakers. In reality there are more, because power has to run from the power point in the front of the room, there's also cables for the TV, and so on. So maybe 12-15 cables to run. In the past I tried to shove this into the corner, but even this was too messy.
So I went to the local hardware store and bought this:
It is corrugated nylon air conditioning conduit. In reality your hardware store will sell all sorts of conduits, PVC for plumbing, even cable conduits. However those cable conduits were not suitable for me because they are rather small, and designed to run maybe 2-3 cables only. Before you go shopping, bundle your cables together to get an estimate of how much diameter you will need.
As you can see, the A/C conduit comes in sections with one male and one female end. You may even be able to find accessories and conduits of various lengths.
Stuffing the cable through the conduit is difficult. As more cables go in, the available diameter decreases and it gets harder. I had to use a long rod to get the cables through. Tape the end of your cable to the rod, then push the rod through the conduit. Do this in sections, then join the conduit sections together when you are done. If need be, you can paint or wrap the conduit to help make it visually less prominent.
There are many other options:
- Spiral cable wraps.
- Flat conduits that can go under your rug. For this to work, you need thick rug underlay to raise your rug and make the bulge from the conduit less prominent.
- Cable ties, either nylon or velcro. I don't like these because your cables are still visible.
- Cable boxes, for storing bunched up cables.
