metasharp
- Joined
- Oct 21, 2022
- Messages
- 120
- Likes
- 70
Hello,
what is the impact of using a cable adapter regarding the signal quality?
1- For example, let's say we have an AMP with 3 front outputs :
- A-XLR4 : Amp's XLR 4 pins Balanced front output
- A-J635 : Jack 6,35mm Unbalanced Single Ended front output
- A-J35 : Jack 3,5mm Unbalanced Single Ended front output
2- We have a HeadPhone with a cable's plug different from the one we want to plug it in.
- HP-XLR4 would be an HeadPhone with a XLR 4 pins cable's plug
- HP-J635 would be an HeadPhone with a Jack 6,35mm cable's plug
- HP-J35 would be an HeadPhone with a Jack 3,5mm cable's plug
3- What happens to the signal when we connect that way (and is it even possible for Jack to XLR?) in terms of signal quality :
X6- A-XLR4 to adapter to HP-J635
X3- A-XLR4 to adapter to HP-J35
6X- A-J635 to adapter to HP-XLR4
63- A-J635 to adapter to HP-J35
3X- A-J35 to adapter to HP-XLR4
36- A-J35 to adapter to HP-J635
(X6, X3, .... are adapter ids to refer to those scenarios below in the replies to this thread)
4- Are there some adapters brands better than others in terms of quality or is even the cheapest one exactly the same result as super expensive ones?
- I was advised to go for Portento Audio ones for example for X6 and X3 since I have an XP-XLR4 headphone.
- Some say to void multimaterial adapters (copper/silver for example), does that make sense regarding measures?
5- Is it perfectly acceptable to do X6+63 to replace directly an X3 which one may not have?
Thanks for enligthing me.
