PashkaTLT
Hello,
I recently got my new custom made speakers from Sounfdield Audio and while I love the sound, there's a problem with clearly audible buzzing noise from the mid-range coaxial driver.
The midrange coaxial drivers ( B&C 12CLX64 12" from parts-express.com) always produce buzzing noise, coming from the HF driver at the center of the coaxial driver, even when no sound is playing. I've recorded this buzz (one unamplified and another amplified for better hearing):
https://ra.ae/unamplified.mp3
https://ra.ae/amplified.mp3
The buzz is always there, as long as the speakers are turned on. It doesn't matter what volume is set, or what's connected or not connected - it's always there. So even if only the power cable is connected (and no other cables), as soon as the speaker is turned on - the buzzing noise appears. I thought that maybe there's some issue in my electrical grid, so I tried ~7 different power outlets in house, I tried 2 expensive power conditioners, I tried a cheater plug (3-prong to 2-prong), I switched off all my electrical lines in my house and left only one, with the only device connected being the speaker - it doesn't help, the buzz is always there.
On the right speaker (slave) the noise is considerable larger than on my left speaker (master). It's also there on the left one, but it doesn't bother me me much, but the buzz on the right speaker I can clearly hear from my listening position (about 4-5' away).
I suspect it may be software issue, because a couple of times when I was working in Hypex Filter Design the noise disappeared, or vice versa - appeared when I changed something. The first time it disappeared when I simply moved the volume slider in Hypex Filter Design (HFD). It did not come back after speakers were turned off and on and I thought that I solved the issue. But after 1 or 2 days, it came back again, and nothing I change in software makes me go away. Then I was working in HFD yesterday, setting up EQ and after I changed something, the noise increased (I believe on both speakers) and now it's still there and I can hear it very well.
I tried updating to latest firmware (5.82), but it didn't help. Again, this noise is always there, even if nothing is playing and nothing is connected.
Any ideas why is there this buzzing noise and what I could do to remove it?
