Buying Advice for a 2.0/2.1 Setup for a Newbie?
Nolaw
Hello everyone. I was hoping the community here could give me some advice on what to purchase...hoping to make use of some of the current sales to better outfit my listening space.
My Setup: Two KEF R7 Meta + TBD SUB (Might be an old Dayton Audio SUB-1500, open to suggestions for something new as well. Maybe Wiim SUB?). A Walnut Rega Planar 3 50th anniversary turntable w/ Rega Exact MM cartridege and Neo PSU Mk2 (no phono preamp and no ground wire). Google cast speakers throughout the home for whole home audio.
Music sources are usually Spotify, Vinyl, personal Plex server with typically FLAC files
Ideally I would like the system to function at a high level without breaking the bank too much. It will be used exclusively for music. I will be the primary user but some less tech savvy people may use it from time to time so simplicity can be helpful. It will be in a prominent area in the house so good looks / clean looks are a plus. Below I have listed some possible options based on my research and could use help comparing them.
P.S. If anyone has a recommendation for a quality piece of furniture to house the equipment and some vinyl records that would be awesome!
Option 1: Wiim Ultra (built in phono preAmp) @ $263 + Wiim VibeLink Amp (200 wpc @ 4 ohm) @ $239 = $503
***Is the Wiim Ultra built in phono preamp generally good enough with my MM cartridge Rega TT?***
Option 2: Wiim Ultra (built in phono preAmp) @ $263 + a different Amp
Possible other amps?:
Two Fosi V3 Mono @ $226.10
3e Audio A5 or A7 Stereo class D amplifier
Topping PA5 II Stereo Amplifier
BasX A2 Stereo Amplifier
IOM Ultra
AUDIOPHONICS AP300-S250NC Power Amplifier Ncore NC252MP
Option 3: Wiim Pro Plus @ $175 + An Amp (VibeLink, Fosi V3, etc) + Phono PreAmp? (Ex. Fosi X5 @ 93.50 / Cambridge Alva Solo @ $249 / Schiit Mani 2 @ $149) = Variable
Option 4: Wiim Amp Ultra (does not have a phono preamp) @ $529 + Phono PreAmp? (Ex. Fosi X5 @ 93.50 / Cambridge Alva Solo @ $249 / Schiit Mani 2 @ $149)
Option 5: Some other All in one streamer/amp/DAC w/ phono PreAmp that includes Google Cast (the rest of the whole house audio I have been using google cast). I haven't been able to find a device which fits this. Marantz Stereo 70s or Marantz M1 are close but no google cast.
Option 6: Something else (Fosi ZP3 + ???, fancier Amp + Wiim pro plus, etc)
If going with a sub, would prefer electronics have bass management. Wiim options seem decent. External phono stages are easy enough if the electronics don't have the RIAA circuit/preamp necessary
Welcome to ASR! Your options so far look pretty good... I have a WiiM Pro + Schiit Mani and although I'm not a vinyl guy, it sounds very clean to my ear.
sub-wise, have a look at SVS if you have the budget, but in general @Chrispy is right, a major factor in how good it ends up sounding will be how well you can EQ / integrate the sub. WiiM units are quite handy for this, so I think you're on the right track.
Fosi amps are also good for the money, may not be a bad idea to get separates rather than put all your eggs in the WiiM amp basket here.
Welcome to ASR,
I consider the MM phono preamp of the WiiM Ultra generally good enough. I think your option '1' will give you the performance, simplicity of operation and aesthetic you seek. Consider working on integrating your Dayton Audio SUB-1500 subwoofer before ordering a replacement.
Welcome to ASR,
I have another use for the Sub already (home theater setup), so if you have any suggestions on a new sub that would be appreciated. Thanks!
Option 6: Bluesound Node Icon.
Edit: scratch that, has no phono input.
Other ASR members have more experience with subwoofers than me. There is this review from October 2023:
My preference is to build a sub. Hands down the best value for money. You can match the performance of a $3k+ sub for maybe $600 and a little work? Not sure on prices. Kits are available if you don't want to design one. I'll build the sub all day long, but that is because I'm not made out of money!
If you buy a subwoofer, I'd steer clear of the less than $1k models. I've had 2 pairs of $500-600 subwoofers that were ok-ish. I was happy at the time, but in retrospect they were hilariously cheap! Boxes are resonant, drivers are inexpensive, and they only extend down to 30hz if you're lucky...even if they claim 20hz! Ports are way too small for serious output. Rated power probably is not accurate.
Admittedly they were fine for what I was doing at the time. Sounded good enough for someone not being critical, or not knowing what a better system would sound like. I connected them to my main speakers (studio monitors) effectively turning 3 way monitors into 4 way monitors. It was fun. Part of the journey. I still have them, partly because I'm too lazy to list them for sale, and partly because I'm a little embarrassed to admit they are mine...
As long as labor is "free" :).....same here in any case.
