But does it resonate? (the furniture)
alaios
Hi all,
last week I did the blasphemy to put a tiny sub (6 1/2 inches woofer) atop of a furniture. This is not any normal furniture. It has been built to be very sturdy based on this guide
and also it isscrewed to the wall.
We have also used a vibrometer and we almost got not any vibrations when we have been hitting the surface. A big table was way too more shaky when tested with vibrometer.
Still I want to learn what is the type of measurement that can check that there is any resonance from that surface. I am sure that people have tried to measureme similar things from wooden floors, thin walls etc. Can you give me such a guide that I can follow?
Regards,
Alex
HarmonicTHD
Hi all,
Regards,
Alex
The free REW software in connection with a ca 80USD UMIK 1 measurement mic will allow you to do a frequency sweep eg 20 to 20kHz. The result will show you possible resonances either caused by the room or by the furniture therein.
I have an old antique cabinet which resonates at ca 30Hz and the speakers aren’t even placed near it. REW shows it quite clearly.
A
alaios
which is the measurement we are talking about? Can you post an example on how it looks like?
restorer-john
What about the old fashioned way - place a glass of water on top of the surface and look for ripples?
What about a glass of beer? It's a better indicator. Wait for the telltale ripples and reward yourself for being so clever in 'locating' the resonance by drinking it. Then, pour another and look for some more 'resonances'... :)
tuga
Oxford, England
How can you tell?
restorer-john
How can you tell?
Because he pressed on a few panels and the resonance peak disappeared?
I've had purpose built HiFi cabinets where the resonances in the long panels were audible, so much so, I gave up and sold the cabinets.
(9ft long, 3 drawer, flat top surfaces and light weight rear panels- all too hard and too annoying to fix) Nobody's fault- you live and you learn. :)
Keith_W
Melbourne, Australia
Since I got my new subwoofers, the whole house resonates. I went through this exercise of using REW's sine wave generator to produce a steady tone, then went around the room pressing on doors, windows, furniture, picture frames trying to locate what was vibrating. I stuck felt pads under picture frames and in door jambs, leaned heavy objects against windows, and did everything I could. In the end I suspected that the walls were resonating (my house is typical cheap Australian brick veneer on wooden frame construction), so I simply cut the frequencies below 30Hz using Acourate. I hope the OP does not have to resort to the same solution.
A
alaios
If this was not a joke I did the experiment. I picked a lightweight plastic jar which I think is way less stable than a glass of water
I played the it is my life way louder of I typically listen and I made a video. Let me know if you spot something
fpitas
Northern Virginia, USA
Doesn't that method require putting shrimp on the barbie?
