EirikDyrset
- Joined
- Mar 26, 2026
- Messages
- 22
- Likes
- 33
- Thread Starter
- #21
Send me a message, and I will share linkWould be fun to experiment with, try out. I’m in the very early stages of planning for a build.
Yes, there are some limits here as of now. I will add possibility for coax later. As for new speakers, you can add custom speakers your self. The library will however grow much over the next weeks.I am unable to proceed because there are no coaxial drivers listed, or the woofers I want to use. Is it limited to two way only?
Thanks for the input!Here are a couple of things i noticed while quickly going through it.
1. when choosing a vented box, it doesn't seem to carry over to later stages (nothing about port size or a hole for it)
2. prices are in NOK
3. no projected frequency response
Thank you for your feedback! Glad you think it's promising.Just tried it. It has the beginnings of an amazing tool! The visual part alone is worth developing it for.
It may be that you are trying to work out too many things at the same time - some of the outputs are at a very deep level of detalisation e.g. what hand tools are needed and exact cuts etc. It may be better to concentrate on getting the higher-level stuff right first like (at the expense of details - these can be added later):
- three ways, four-ways, side mounted woofers, subwoofers
- different driver types e.g. horns, waveguides, ribbons etc. shapes e.g. rectangular, oval etc.
- full set of filters available, passive and active
- very significant extension to driver database and verification of the data - it must be trusted
Thanks for the input! Really appreciate it.Great start!!
I would love to see:
- an option to be able to add drivers that are not in the list
- an option to add multiple drivers and driver configurations (like push-pull, push-push, Bessel array, various wiring options like series, parallel, series-parallel, etc.)
Thank you
Thanks a lot!Nice tool, nice UI.
A few immediate issues when testing it for a subwoofer:
- I can't add more than one driver, not until the enclosure part, which is weird, since adding two there will obviously affect the result in the previous page.
- On the enclosure page it says I'm building a bookshelf speaker despite choosing subwoofer earlier in the process.
- The possibility of adding EQ points would of course be useful
Thanks a lot!
* You can select two way, three way og subwoofer at Step 3 Drivers.
It is possible to have two woofers now, but not more, yet. But that is added to the list, and will be included in the near futureYes, but what if I want to build a subwoofer with two drivers? Or four for that matter.![]()
Thannks! Yes, still a lot of things missing. But I am working my way through the roadmap. Anything in particular you where thinking about?Looks really good, Eirik. Still a bit to go to make it a one stop shop though.
