This is a great development by Roon folks to enable fast and easy build of a Roon music server using small form factor "NUC" Intel computers. I love the support they have for auto update and integration of Linux+Roon having had to do that myself on other appliances (and failing).
So if you don't want to build a Windows or Mac Server, and hate dealing with intricacies of Linux, this is an ideal solution: https://kb.roonlabs.com/Roon_Optimized_Core_Kit
Let's first explain what Roon OS is, and then we can talk about Roon Optimized Core Kit.
Roon OS is a custom Linux based operating system, tailored for running Roon Server and providing a best-in-class, appliance-type user experience to host the Roon Core.
Roon OS boots very quickly and integrates with the Roon suite of applications for updating, discovery, configuration, and support. It also comes with a disaster recovery mechanism.
Roon OS includes a web-based administration UI which allows users to check system status, configure network settings, start or stop services, and factory-reset the device from desktop and mobile web browsers. The Roon application also can locate Roon OS on the network and give the user a link to open this web UI in a browser.
To allow partner manufacturers to build custom turn-key Roon Server based offerings, Roon OS has a few hooks for manufacturers to customize Roon OS to their specific device.
So, what is Roon Optimized Core Kit (ROCK) then?
ROCK is a do-it-yourself build of Roon OS. To use it, you will need to buy hardware components, assemble them, and install ROCK.
This is is what ROCK offers (and what it doesn't offer):
See the link for more information.
- It is completely free ($0)
- It is an alternative to Windows/MacOS/Ubuntu/Arch/etc..
- It runs Roon (The stock Linux RoonServer to be exact), but does not come with a Roon membership. You can sign up for a free trial or purchase a Roon membership here
- It is an extremely lightweight Linux-based operating system. Much more on the scale of an embedded machine than a desktop or server operating system.
- It is a turn-key image with all required pieces to make a Linux based Roon appliance without any prior knowledge of Roon or Linux
- It should be near silent or completely silent, depending on hardware
- It auto-updates in an experience similar to Roon, integrated fully into the Roon Remotes' Settings->About page.
- OS updates will blow away any "custom" changes you may have made to the OS, so we do not recommend you try to tweak the OS
- It provides a web browser based configuration for networking setup, factory reset, power/reboot, etc...
- It can not run additional software, nor does it support any customizations or modifications to the operating system
- It has working multichannel digital audio output support (if the hardware has a working HDMI or DisplayPort connector)
