Just wanted to share my build and some measurements of the Keramiskas DIY speaker (Meniscus Audio Link), designed by Craig Salin. This is my first ever speaker build and complex wood working project. I picked this speaker since it looked like a good beginner DIY build, and numerous people who've listened to them have commented on their great sound. I thought they came out reasonably well (the finish could have been better), and sound great too. Some build pics are in the attachments.
I had a few modifications from the original build plans; I opted for the component upgrades, used Baltic Birch instead of MDF, made my back panel removable, and used more and thicker tile on the inside (for constrained layer damping) than specified in the design, which led me to enlarge the box dimensions slightly. One speaker weighs a hefty 32 lbs. I also embedded magnets for a magnetic grille (not built yet).
My (not well controlled) measurements were done in my HT room using a Denon 3600H AVR with a UMIK-1 placed 12" from tweeter on its axis; REW software was used. Also plotted are my old Ascend Acoustics CBM-170 (reviewed on ASR) measured in a similar fashion, which is my point of comparison. I have some acoustic panels around the test setup, but there are a lot of room modes and artifacts showing up in both speaker's response.
Freq Resp 1/48 smoothing (Green = Keramiskas, Brown = Ascend CBM170)
Distortion plot for Keramiskas:
Sound wise, bass extension is much lower than I would have expected; roll off starts at 40 Hz, and I would estimate a -3 dB point of around 30-35 Hz (Ascends are listed to have -3 dB around 53-58 Hz, approximately indicated by the cursor on the plot), which is great for a 2-way bookshelf with a 5" driver. I wonder if the high amount of internal cabinet damping from the tiles is helping bass extension, which speakers don't normally have. Highs have a dip in the 6-10 kHz region (Ascends are noted to be bright sounding), and don't roll-off at 20 kHz. Distortion plot is also included, shows increasing distortion for bass freqs (Ascends are lower, <1% everywhere). Subjectively, the stereo imaging of these speakers is excellent, instruments are noticeably more pin-point than the Ascends, and they throw a wide sound stage. Highs are smoother/less harsh sounding, and bass is clearly stronger. Sensitivity is a lot lower than the Ascends (Ascends are -7 dB to match levels), so these are power hungry.
Open to ideas of how to improve these measurements with the limited tools I have, I'm relatively inexperienced with these type of measurements. Hope someone finds this useful; I thought this was a fun project and yielded a great sounding speaker.
