EJ3
To get 4 OHM from two 4 Ohm loads (as I have each of my pair of dual 4 Ohm Voice coil 12" ported [tuned to 29 Hz] subs arranged) chose the second option:For speakers I'm not going to power via Wiim Amp Ultra, I'm looking at true "dumb power" amp 3e A7 Mono
I'm also trying to understand taking 4ohm speakers already reco'd, wiring in parallel the pair is now 2ohm?
Dayton apparently designed for this with the RSS210HO-44
And with a Stereo PROTON D 1200 summed mono (55 LPF, 70 HPF to each (1% distortion @ 40 HZ):
1100 watts RMS each.
So, do it right & you are not at 2 Ohms.
IF I wired the speakers for 2 Ohms:
I would have 1700 watts a channel (1 % distortion at 40 Hz)
In both cases the amp was run on an: Amplifier Dyno AD-1
This AMP is no joke (and some, such as mine) have a switch to run them in bridged mono mode (@ 4 Ohms, not 2 Ohms [unless you like replacing CAPS])
