- Thread Starter
- #21
Hmmm...It might be tough to keep the ls 50s secured without some sort of bracket or fixturing
https://www.mcmaster.com/product/8422N13
Also for between the stacked units
And the bottom-most one gets the spikes
oh be still my heartYou can always escalate later.
VERY good point. For in between the speakers and multiple stacked cubes, see the Mcmasters idea above.When you think about a tall, thin design you will also have to think of a way to make it stable.
You can eventually end up taking more space than you thought.
Hi, I've been picking up OG LS50s at reasonable prices over the years, getting to the point I want to improve my implementation, specifically placement.
In shopping for "proper" stands I can't believe the costs involved even at the low end, but at the high end more than I paid for the speakers!
I've also decided to do supplementary bass, high up enough in frequency to mean "not just subwoofer" maybe even 600Hz (ish) ? but certainly over 200Hz, directionality still relevant, stereo needed for localization / imaging.
So I'm thinking, look for mid-bass boxen that can ACT AS stands, in effect convert my LS50s into floor-standing 3-way speakers
either dedicated to the range between there and 60-80Hz sub territory, or (holy grail would be) "do it all woofer + sub" units within my desired form factor.
Off-grid, tiny-house or even van camping context, so looking for as small as possible to accomplish the assignment, and passive (or DC-driven ? designed for car / boats?) reco's only please not AC powered.
I care almost nothing for aesthetics, only SQ functionality and VALUE is top priority!
Assume a biggish room with EQ room correction and SOTA bass management to optimize crossovers, and for power say Adcom GFA-555 levels, low Z-out plenty of current rather than Class D.
So, sizing: LS50 footprint is 8x11" (20.3 x 28cm) so that would ideally be the minimum, and ideal maximum say 12" square (30.5cm). Deeper is fine more so than going past say 15" wide but willing to be flexible for a spectacular good value result.
Vertically the target range is 24 up to say 36" (60-90cm), while the true ideal would be 12" height so multiple boxen that can be stacked - to accommodate my increasing tendency to work / listen standing up, plus dancing sometimes.
I MIGHT go DIY - feel free to give form factor suggestions (is a square footprint ideal?)
and reco suitable (reasonably priced) drivers say 8" and up, but 6.5" would be even better.
But meantime the main request here is reco's for suitable pre-built speakers.
I came across Rythmik FM8 - that is purpose-built for the "do it all woofer + sub" use case, but a bit beyond my budget; I'd need to scrimp on the kids' groceries many months to get there.
Willing to buy secondhand, so would be great to get a biggish watch list put together for eBay, Reverb, and CL/FB locally.
Bonus question: should be fine to lay the LS50s on their side if needed? thinking if used for Centre channel when in HT mode 5.2
glad that he threw it out there, though. Now I am looking at that.Very nice, but only as a fantasy! :-0
See the very first word of my title
The price seems reasonable for what you get, n, no plans to get away from RCA conectors if I don't have to & overkill for what I would want to do.Very nice, but only as a fantasy! :-0
Yes, if we take the budget part of the title seriously... This is probably the answer. I was able to get some used Bic F12s for $125 each. Put a couple cinderblocks on top of the sub, ls50 on top of that, and hold it all together with some tie down straps. Aesthetics, 0/10, value for dollar 9/10+?Just buy a pair of subs and if they are too short , lift them up with a bottom support or box.
You can skip the cinder block, just lift the sub with some small wood cube, and put some used books on top of the sub to pit the speakers a bit higher. Not the best looking but is good on budget.Yes, if we take the budget part of the title seriously... This is probably the answer. I was able to get some used Bic F12s for $125 each. Put a couple cinderblocks on top of the sub, ls50 on top of that, and hold it all together with some tie down straps. Aesthetics, 0/10, value for dollar 9/10+?
I wrote this primarily for inspiration).but only as a fantasy! :-0
The primary goal is to maximise the LS50 SPL up to, but not past the point of SQ or safety risk.Do you need really high SPL?
