Budget subwoofer < £200
sharock
I have a pair of iLoud Micro Monitors at work that I am considered pairing with a sub.
Is there anything better than the PreSonus Sub8 in this price range that is also compact? It's £158 on Amazon UK.
I've also seen the Fostex SUBmini2 for around £140, but that doesn't have a HPF on the output. It does look cute though with its 5" driver!
Must have an output since the iLouds don't have a sub-out.
Vict0r
The Netherlands
I've been looking in the same direction, but it seems the Sub8 is the best option.
S
sharock
Received the Sub8 today, hastily hooked it up and took some very quick measurements. Will need to see if I can improve things a bit more and maybe use REW to do some correction. At the moment I am applying some filters to correct the iLoud MM's quasi-anechoic response. All this effort for my work office setup. :D
