Budget Standalone "Toslink > DSP > Toslink" with Camilladsp. Set up instructions for newbies.
Trying to use a Xfi HD like in the original post but cant get it to work. I cant find the right input/output in alsamixer/camilladsp. Any tips?
post screenshot of alsamixer
Here is alsamixer, arecord and cat of the card.
I tried for several hours now - i can get analog line in (hw:HD,0,0 as in the picture) to work, both with optical and analog out (hw:HD,0,0 and hw:HD,2,0).
But I cant find the optical input anywhere. Is this a driver problem? USB class 1?
OK, please copy and post here as CODE text (not screenshot) complete output of 'amixer -c 0 contents' so that we see all controls of that card. Screenshots do not show complete info and do not allow text searching.
What is your cdsp config ? Only 2ch and S16LE or S24LE3 formats are supported on the capture side, at those listed rates.
cdsp is only 2ch, until now its 48k s16le in and out.
philk92@camilladsp:~$ amixer -c 0 contents
numid=6,iface=MIXER,name='PCM Playback Switch'
; type=BOOLEAN,access=rw------,values=1
: values=on
numid=7,iface=MIXER,name='PCM Playback Volume'
; type=INTEGER,access=rw---R--,values=2,min=0,max=128,step=0
: values=79,79
| dBminmax-min=-64.00dB,max=0.00dB
numid=8,iface=MIXER,name='PCM Capture Source'
; type=ENUMERATED,access=rw------,values=1,items=3
; Item #0 'Mic'
; Item #1 'Line'
; Item #2 'Phonograph'
: values=1
numid=4,iface=PCM,name='Capture Channel Map'
; type=INTEGER,access=r--v-R--,values=2,min=0,max=36,step=0
: values=3,4
| container
| chmap-fixed=FL,FR
numid=1,iface=PCM,name='Playback Channel Map'
: values=0,0
| container
| chmap-fixed=FL,FR
numid=5,iface=PCM,name='Capture Channel Map',device=1
: values=0,0
| container
| chmap-fixed=FL,FR
numid=2,iface=PCM,name='Playback Channel Map',device=1
: values=0,0
| container
| chmap-fixed=FL,FR
numid=3,iface=PCM,name='Playback Channel Map',device=2
: values=3,4
| container
| chmap-fixed=FL,FR
[/ISPOILER]
OK, so what specifically does not work in CDSP? CDSP logs should say more.
Please use the CODE tag for terminal printouts so that the output is nicely readable. Non-CODE output drops white spaces and reformats.
I don't find the optical input anywhere. With analog input everything works like expected.
Post code-formatted lsusb -v -d VID:PID (those hexa numbers listed in lsusb for your soundcard) to see what the usb device actually reports to the usb-audio driver. My 2 cents is no SPDIF type input terminal is mentioned, not giving any info to the driver (hence just line/mic/phono).
Did you try the second device - hw:HD,1? Also capture format S24LE3? SPDIF format is by default 24bit, but the preamble can specify that only 16 bits are significant. Does your capture rate fit the incoming SPDIF rate? These USB SPDIF interfaces implement typically no way to report the incoming rate and the capture device must be opened in the correct rate to function properly.
I think hw:HD,1 is the front input 3.5mm mic.
philk92@camilladsp:~$ lsusb -v -d 041e:3232
Bus 001 Device 002: ID 041e:3232 Creative Technology, Ltd Sound Blaster Premium HD [SBX]
Couldn't open device, some information will be missing
Negotiated speed: Full Speed (12Mbps)
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0 [unknown]
bDeviceSubClass 0 [unknown]
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x041e Creative Technology, Ltd
idProduct 0x3232 Sound Blaster Premium HD [SBX]
bcdDevice 1.00
iManufacturer 1 Creative Technology
iProduct 2 USB Sound Blaster HD
iSerial 3 0000000G
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x0501
bNumInterfaces 6
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 1 Audio
bInterfaceSubClass 1 Control Device
bInterfaceProtocol 0
iInterface 0
AudioControl Interface Descriptor:
bLength 12
bDescriptorType 36
bDescriptorSubtype 1 (HEADER)
bcdADC 1.00
wTotalLength 0x008b
bInCollection 4
baInterfaceNr(0) 1
baInterfaceNr(1) 2
baInterfaceNr(2) 3
baInterfaceNr(3) 4
bLength 12
bDescriptorType 36
bDescriptorSubtype 2 (INPUT_TERMINAL)
bTerminalID 1
wTerminalType 0x0101 USB Streaming
bAssocTerminal 0
bNrChannels 2
wChannelConfig 0x0003
Left Front (L)
Right Front (R)
iChannelNames 0
iTerminal 0
bLength 10
bDescriptorType 36
bDescriptorSubtype 6 (FEATURE_UNIT)
bUnitID 2
bSourceID 1
bControlSize 1
bmaControls(0) 0x01
Mute Control
bmaControls(1) 0x02
Volume Control
bmaControls(2) 0x02
Volume Control
iFeature 0
bLength 9
bDescriptorType 36
bDescriptorSubtype 3 (OUTPUT_TERMINAL)
bTerminalID 3
wTerminalType 0x0301 Speaker
bAssocTerminal 0
bSourceID 2
iTerminal 0
bLength 12
bDescriptorType 36
bTerminalID 4
bAssocTerminal 0
bNrChannels 2
Left Front (L)
Right Front (R)
iChannelNames 0
iTerminal 0
bLength 9
bDescriptorType 36
bTerminalID 6
wTerminalType 0x0602 Digital Audio Interface
bAssocTerminal 0
bSourceID 4
iTerminal 0
bLength 12
bDescriptorType 36
bTerminalID 10
wTerminalType 0x0201 Microphone
bAssocTerminal 0
bNrChannels 2
Left Front (L)
Right Front (R)
iChannelNames 0
iTerminal 0
bLength 12
bDescriptorType 36
bTerminalID 12
wTerminalType 0x0603 Line Connector
bAssocTerminal 0
bNrChannels 2
Left Front (L)
Right Front (R)
iChannelNames 0
iTerminal 0
bLength 12
bDescriptorType 36
bTerminalID 14
wTerminalType 0x0708 Phonograph
bAssocTerminal 0
bNrChannels 2
Left Front (L)
Right Front (R)
iChannelNames 0
iTerminal 0
bLength 9
bDescriptorType 36
bDescriptorSubtype 5 (SELECTOR_UNIT)
bUnitID 16
bNrInPins 3
baSourceID(0) 10
baSourceID(1) 12
baSourceID(2) 14
iSelector 0
bLength 9
bDescriptorType 36
bTerminalID 17
bAssocTerminal 0
bSourceID 16
iTerminal 0
bLength 12
bDescriptorType 36
bTerminalID 7
wTerminalType 0x0605 SPDIF interface
bAssocTerminal 0
bNrChannels 2
Left Front (L)
Right Front (R)
iChannelNames 0
iTerminal 0
bLength 9
bDescriptorType 36
bTerminalID 9
bAssocTerminal 0
bSourceID 7
iTerminal 0
Endpoint Descriptor:
bLength 9
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0002 1x 2 bytes
bInterval 10
bRefresh 0
bSynchAddress 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bInterfaceSubClass 2 Streaming
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 2
iInterface 0
AudioStreaming Interface Descriptor:
bLength 7
bDescriptorType 36
bDescriptorSubtype 1 (AS_GENERAL)
bTerminalLink 1
bDelay 0 frames
wFormatTag 0x0001 PCM
bLength 11
bDescriptorType 36
bDescriptorSubtype 2 (FORMAT_TYPE)
bFormatType 1 (FORMAT_TYPE_I)
bNrChannels 2
bSubframeSize 2
bBitResolution 16
bSamFreqType 1 Discrete
tSamFreq[ 0] 48000
bLength 9
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 5
Transfer Type Isochronous
Synch Type Asynchronous
Usage Type Data
wMaxPacketSize 0x00c4 1x 196 bytes
bInterval 1
bRefresh 0
bSynchAddress 1
AudioStreaming Endpoint Descriptor:
bLength 7
bDescriptorType 37
bDescriptorSubtype 1 (EP_GENERAL)
bmAttributes 0x00
bLockDelayUnits 0 Undefined
wLockDelay 0x0000
bLength 9
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 17
Synch Type None
Usage Type Feedback
wMaxPacketSize 0x0003 1x 3 bytes
bInterval 1
bRefresh 5
bSynchAddress 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 1
bDelay 0 frames
bLength 11
bDescriptorType 36
bNrChannels 2
bSubframeSize 3
bBitResolution 24
tSamFreq[ 0] 48000
bLength 9
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0126 1x 294 bytes
bInterval 1
bRefresh 0
bSynchAddress 1
bLength 7
bDescriptorType 37
bmAttributes 0x00
wLockDelay 0x0000
bLength 9
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 1
bRefresh 5
bSynchAddress 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 3
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 1
bDelay 0 frames
bLength 11
bDescriptorType 36
bNrChannels 2
bSubframeSize 2
bBitResolution 16
tSamFreq[ 0] 96000
bLength 9
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0184 1x 388 bytes
bInterval 1
bRefresh 0
bSynchAddress 1
bLength 7
bDescriptorType 37
bmAttributes 0x00
wLockDelay 0x0000
bLength 9
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 1
bRefresh 5
bSynchAddress 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 4
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 1
bDelay 0 frames
bLength 11
bDescriptorType 36
bNrChannels 2
bSubframeSize 3
bBitResolution 24
tSamFreq[ 0] 96000
bLength 9
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0246 1x 582 bytes
bInterval 1
bRefresh 0
bSynchAddress 1
bLength 7
bDescriptorType 37
bmAttributes 0x00
wLockDelay 0x0000
bLength 9
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 1
bRefresh 5
bSynchAddress 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 0
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 1
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 4
bDelay 0 frames
bLength 11
bDescriptorType 36
bNrChannels 2
bSubframeSize 2
bBitResolution 16
tSamFreq[ 0] 44100
bLength 9
bDescriptorType 5
bEndpointAddress 0x04 EP 4 OUT
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x00b4 1x 180 bytes
bInterval 1
bRefresh 0
bSynchAddress 4
bLength 7
bDescriptorType 37
bmAttributes 0x00
wLockDelay 0x0000
bLength 9
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 1
bRefresh 5
bSynchAddress 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 2
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 4
bDelay 0 frames
bLength 11
bDescriptorType 36
bNrChannels 2
bSubframeSize 3
bBitResolution 24
tSamFreq[ 0] 44100
bLength 9
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x010e 1x 270 bytes
bInterval 1
bRefresh 0
bSynchAddress 4
bLength 7
bDescriptorType 37
bmAttributes 0x00
wLockDelay 0x0000
bLength 9
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 1
bRefresh 5
bSynchAddress 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 3
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 4
bDelay 0 frames
bLength 11
bDescriptorType 36
bNrChannels 2
bSubframeSize 2
bBitResolution 16
tSamFreq[ 0] 48000
bLength 9
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bRefresh 0
bSynchAddress 4
bLength 7
bDescriptorType 37
bmAttributes 0x00
wLockDelay 0x0000
bLength 9
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 1
bRefresh 5
bSynchAddress 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 4
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 4
bDelay 0 frames
bLength 11
bDescriptorType 36
bNrChannels 2
bSubframeSize 3
bBitResolution 24
tSamFreq[ 0] 48000
bLength 9
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bRefresh 0
bSynchAddress 4
bLength 7
bDescriptorType 37
bmAttributes 0x00
wLockDelay 0x0000
bLength 9
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 1
bRefresh 5
bSynchAddress 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 5
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 4
bDelay 0 frames
bLength 11
bDescriptorType 36
bNrChannels 2
bSubframeSize 2
bBitResolution 16
tSamFreq[ 0] 96000
bLength 9
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bRefresh 0
bSynchAddress 4
bLength 7
bDescriptorType 37
bmAttributes 0x00
wLockDelay 0x0000
bLength 9
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 1
bRefresh 5
bSynchAddress 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 6
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 4
bDelay 0 frames
bLength 11
bDescriptorType 36
bNrChannels 2
bSubframeSize 3
bBitResolution 24
tSamFreq[ 0] 96000
bLength 9
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bRefresh 0
bSynchAddress 4
bLength 7
bDescriptorType 37
bmAttributes 0x00
wLockDelay 0x0000
bLength 9
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 1
bRefresh 5
bSynchAddress 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 7
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 4
bDelay 0 frames
wFormatTag 0x2001 IEC1937_AC-3
bLength 11
bDescriptorType 36
bFormatType 3 (FORMAT_TYPE_III)
bNrChannels 2
bSubframeSize 2
bBitResolution 16
tSamFreq[ 0] 44100
bLength 9
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bRefresh 0
bSynchAddress 4
bLength 7
bDescriptorType 37
bmAttributes 0x00
wLockDelay 0x0000
bLength 9
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 1
bRefresh 5
bSynchAddress 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 8
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 4
bDelay 0 frames
bLength 11
bDescriptorType 36
bNrChannels 2
bSubframeSize 2
bBitResolution 16
tSamFreq[ 0] 48000
bLength 9
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bRefresh 0
bSynchAddress 4
bLength 7
bDescriptorType 37
bmAttributes 0x00
wLockDelay 0x0000
bLength 9
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 1
bRefresh 5
bSynchAddress 0
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 0
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 1
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 17
bDelay 0 frames
bLength 11
bDescriptorType 36
bNrChannels 2
bSubframeSize 2
bBitResolution 16
tSamFreq[ 0] 48000
bLength 9
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 37
Usage Type Implicit feedback Data
bInterval 1
bRefresh 0
bSynchAddress 0
bLength 7
bDescriptorType 37
bmAttributes 0x00
wLockDelay 0x0000
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 2
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 17
bDelay 0 frames
bLength 11
bDescriptorType 36
bNrChannels 2
bSubframeSize 3
bBitResolution 24
tSamFreq[ 0] 48000
bLength 9
bDescriptorType 5
bmAttributes 37
bInterval 1
bRefresh 0
bSynchAddress 0
bLength 7
bDescriptorType 37
bmAttributes 0x00
wLockDelay 0x0000
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 3
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 17
bDelay 0 frames
bLength 11
bDescriptorType 36
bNrChannels 2
bSubframeSize 2
bBitResolution 16
tSamFreq[ 0] 96000
bLength 9
bDescriptorType 5
bmAttributes 37
bInterval 1
bRefresh 0
bSynchAddress 0
bLength 7
bDescriptorType 37
bmAttributes 0x00
wLockDelay 0x0000
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 4
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 17
bDelay 0 frames
bLength 11
bDescriptorType 36
bNrChannels 2
bSubframeSize 3
bBitResolution 24
tSamFreq[ 0] 96000
bLength 9
bDescriptorType 5
bmAttributes 37
bInterval 1
bRefresh 0
bSynchAddress 0
bLength 7
bDescriptorType 37
bmAttributes 0x00
wLockDelay 0x0000
bLength 9
bDescriptorType 4
bInterfaceNumber 4
bAlternateSetting 0
bNumEndpoints 0
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 4
bAlternateSetting 1
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 9
bDelay 0 frames
bLength 11
bDescriptorType 36
bNrChannels 2
bSubframeSize 2
bBitResolution 16
tSamFreq[ 0] 44100
bLength 9
bDescriptorType 5
bEndpointAddress 0x85 EP 5 IN
bmAttributes 37
bInterval 1
bRefresh 0
bSynchAddress 0
bLength 7
bDescriptorType 37
bmAttributes 0x00
wLockDelay 0x0000
bLength 9
bDescriptorType 4
bInterfaceNumber 4
bAlternateSetting 2
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 9
bDelay 0 frames
bLength 11
bDescriptorType 36
bNrChannels 2
bSubframeSize 3
bBitResolution 24
tSamFreq[ 0] 44100
bLength 9
bDescriptorType 5
bmAttributes 37
bInterval 1
bRefresh 0
bSynchAddress 0
bLength 7
bDescriptorType 37
bmAttributes 0x00
wLockDelay 0x0000
bLength 9
bDescriptorType 4
bInterfaceNumber 4
bAlternateSetting 3
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 9
bDelay 0 frames
bLength 11
bDescriptorType 36
bNrChannels 2
bSubframeSize 2
bBitResolution 16
tSamFreq[ 0] 48000
bLength 9
bDescriptorType 5
bmAttributes 37
bInterval 1
bRefresh 0
bSynchAddress 0
bLength 7
bDescriptorType 37
bmAttributes 0x00
wLockDelay 0x0000
bLength 9
bDescriptorType 4
bInterfaceNumber 4
bAlternateSetting 4
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 9
bDelay 0 frames
bLength 11
bDescriptorType 36
bNrChannels 2
bSubframeSize 3
bBitResolution 24
tSamFreq[ 0] 48000
bLength 9
bDescriptorType 5
bmAttributes 37
bInterval 1
bRefresh 0
bSynchAddress 0
bLength 7
bDescriptorType 37
bmAttributes 0x00
wLockDelay 0x0000
bLength 9
bDescriptorType 4
bInterfaceNumber 4
bAlternateSetting 5
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 9
bDelay 0 frames
bLength 11
bDescriptorType 36
bNrChannels 2
bSubframeSize 2
bBitResolution 16
tSamFreq[ 0] 96000
bLength 9
bDescriptorType 5
bmAttributes 37
bInterval 1
bRefresh 0
bSynchAddress 0
bLength 7
bDescriptorType 37
bmAttributes 0x00
wLockDelay 0x0000
bLength 9
bDescriptorType 4
bInterfaceNumber 4
bAlternateSetting 6
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 9
bDelay 0 frames
bLength 11
bDescriptorType 36
bNrChannels 2
bSubframeSize 3
bBitResolution 24
tSamFreq[ 0] 96000
bLength 9
bDescriptorType 5
bmAttributes 37
bInterval 1
bRefresh 0
bSynchAddress 0
bLength 7
bDescriptorType 37
bmAttributes 0x00
wLockDelay 0x0000
bLength 9
bDescriptorType 4
bInterfaceNumber 5
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 0 [unknown]
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.11
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 (null)
wDescriptorLength 33
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bEndpointAddress 0x86 EP 6 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 1
OK, look at my GPT 5 conversation, no need to reword it :-) :
Analyze the attached USB descriptor for linux alsa usb. Problem: SPDIF input is not available in amixer:
; Item #0 'Mic'
; Item #1 'Line'
: values=1
Note that spdif input is there:
bLength 12
bDescriptorType 36
bTerminalID 7
bAssocTerminal 0
bNrChannels 2
Left Front (L)
Right Front (R)
iChannelNames 0
iTerminal 0
but the selector unit offers only the three other input terminals:
bLength 9
bDescriptorType 36
bUnitID 16
bNrInPins 3
baSourceID(0) 10
baSourceID(1) 12
baSourceID(2) 14
iSelector 0
Alsa usb driver creates two capture devices - see the attached screenshot of arecord -l. Could the SPDIF input be part of the second device (hw:HD,1)?
Short answer: Yes — the SPDIF input is exposed as a separate capture PCM (hw:HD,1).
Why:
  • SPDIF input path: IT 7 (SPDIF) → OT 9 (USB Streaming) → AudioStreaming Interface #4 (endpoints 0x85 IN, altsets for 44.1/48/96 kHz, 16/24-bit).
  • Analog inputs path: ITs 10/12/14 → Selector Unit 16 → OT 17 (USB Streaming) → AudioStreaming Interface #3 (endpoints 0x82 IN, 48/96 kHz, 16/24-bit).
  • The mixer control “PCM Capture Source” belongs to Selector Unit 16 on the analog path only, so it lists Mic/Line/Phono and not SPDIF.
How to verify/use:
  • Quick proof (44.1 kHz is only on SPDIF path):
    • arecord -D hw:HD,1 -r 44100 -f S16_LE -c 2 -V mono -v /dev/null # should open
    • arecord -D hw:HD,0 -r 44100 -f S16_LE -c 2 # should fail or resample
  • Inspect ALSA stream mapping:
    • cat /proc/asound/card0/stream0
    • cat /proc/asound/card0/stream1 # one will show Interface 4, wTerminalLink 9 (SPDIF)
  • Record SPDIF:
    • arecord -D hw:HD,1 -r 48000 -f S24_3LE -c 2 spdif.wav
    • or use 44100/96000 and S16_LE/S24_3LE per the altsettings above.
Note: SPDIF capture likely has no mixer controls (no Feature Unit in that path), so amixer won’t show a source selector for it. Use the separate device hw:HD,1.
Also this seems interesting - The USB descriptor is just a simple graph, one only needs to know how to traverse it as connecting attribs have different names :-)
Explain in the descriptor, how you reached OT 9 (USB Streaming) → AudioStreaming Interface #4 and OT 17 (USB Streaming) → AudioStreaming Interface #3
Here’s exactly how the links are encoded in your dump (USB Audio Class 1.0 rules: an AudioStreaming (AS) interface advertises which Terminal it serves via bTerminalLink in its Class-Specific AS General descriptor).
  1. SPDIF capture path
  • AC graph:
    • IT 7: “wTerminalType 0x0605 SPDIF interface”
    • OT 9: “wTerminalType 0x0101 USB Streaming”, bSourceID 7→ So data flows IT7 → OT9 (to host).
  • AS mapping:
    • Interface Number 4 (alts 1–6) all show:
      • “AS_GENERAL … bTerminalLink 9”
      • Endpoint 0x85 (IN), isoch async
      • Formats include 44.1/48/96 kHz (16/24-bit)
    • Therefore: IT7 (SPDIF) → OT9 (USB Streaming) → AS Interface #4 → EP 0x85 IN → ALSA second capture PCM.
  1. Analog capture path (Mic/Line/Phono via mixer)
  • AC graph:
    • IT 10 (Mic), IT 12 (Line), IT 14 (Phonograph)
    • SU 16: “SELECTOR_UNIT … baSourceID: 10,12,14”
    • OT 17: “wTerminalType 0x0101 USB Streaming”, bSourceID 16→ So data flows IT10/12/14 → SU16 → OT17 (to host).
  • AS mapping:
    • Interface Number 3 (alts 1–4) all show:
      • “AS_GENERAL … bTerminalLink 17”
      • Endpoint 0x82 (IN), isoch async
      • Formats 48/96 kHz (16/24-bit)
    • Therefore: IT10/12/14 → SU16 → OT17 (USB Streaming) → AS Interface #3 → EP 0x82 IN → ALSA first capture PCM.
Why SPDIF isn’t in amixer’s “PCM Capture Source”
  • The mixer control is the Selector Unit 16; it only has sources 10/12/14. The SPDIF path bypasses SU16 (IT7 → OT9), so it appears as a separate capture device (the AS iface #4), not as a selectable source in that mixer.
First - big thanks for your help. You are right - hw:HD,1,0 is the optical input. Almost every TV on earth will give out 48khz, but mine of course not. I changed input to a Moode player with SoX-resampling to 48khz and it worked.
Funny enough, before I wrote my post here, I also tried shooting with GPT. I gave it also all information you had, without the last (lsusb). It changed it opinion from "should be an switch in alsamixer (IEC...)" to "this is a slimmed down version of the Soundblaster without Optical In, only in Windows with prop. drivers..." - any tips for avoiding those "lies/assumptions"?
Thanks again!
I gave it also all information you had, without the last (lsusb)....- any tips for avoiding those "lies/assumptions"?
Well, the lsusb dump is the ultimate and crucial source of info. Without it, the model was just plain guessing. With it - it used its learned knowledge of USB descriptor structure (which is plentiful in the learning materials) to apply to the specific info supplied by me (which for your specific soundcard is basically nonexistent in the learning materials, maybe one or two occurrences over the whole internet, if at all, very hard to dig out). Plus using a good model - I use GPT5 only, all other models so far seemed worse to me (but this may change anytime :-) ).
My free use of GPT5 was used so it changed to 4 (lite?) ... do you think for that kind of usage its worth to go premium?
Thanks again, cheers.
I use LLM mostly for programming new features and there GPT5 vs. 4.1 was a major difference (basically from no go to go). But this case was not so complicated, if the model is provided with required data to work on. IMO not worth the payment unless you need it professionally... I use the 10USD/mo github copilot with 300 GPT5 queries (50 queries free, IIRC).
