Budget dac with asio driver/low latency?
Infinit0
Hello all!
I am wondering if there IS any dac out there with asio driver (not asio4all) and low latency. I play a piano as a midi controller and use a laptop to Connect It but realtek onboard has awful latency 10ms and I need something close to 2-5ms and even with asio4all I cant achieve It.
Buying a USB interface IS an overkill (focusrite or smth like that) so I am thinking if there IS anything that could fit.
I need to have headphones output (amp not needed using low impedance headphones but if has an amp is ok too)
And if posible something small/portable.
Any ideas? Some audioquest (looks like scam), some topping device? Smsl, ifi zen?
Thanks!!!
I will guess that you are using direct USB-MIDI connection from keyboard to computer - if not, please let us know.
So you don't need an interface with MIDI inputs, just a basic audio interface with dedicated low-latency drivers -
the Focusrite Scarlett Solo is modestly priced at US$140.
or for about the same money you can get competing products with full MIDI input/output -
- Behringer UMC204HD US$120 (even cheaper on sale at Sweetwater)
or
- Roland Rubix22 US$175
Tempotec Sonata HD Pro ($40), Sonata HD III ($45), or Sonata BHD ($45) all have a driver with native ASIO interface.
I have not seen latency measurements.
This is a very interesting discussion about wasapi exclusive vs. asio https://gearspace.com/board/music-computers/1376608-asio-still-necessary-low-latency.html . It even shows a setting in Reaper which allows to set small buffers for wasapi exclusive. The guy has exactly the same setup (piano -> midi -> PC -> audio) a is OK with wasapi exclusive + presumably Reaper https://gearspace.com/board/showpost.php?p=15922918&postcount=6
Most likely the onboard Realtek supports wasapi exclusive OK (being an internal-bus-connected device it can potentially have a lower latency than USB-audio devices).
Well I still consider US$140 a modest amount money for a home musician/home recording enthusiast to spend, but wow, those Tempotec dongles are outrageously cheap, and staticV3 is offering a solution which involves no expense at all! We live in good times.
Regarding the stick-with-the-onboard-Realtek option, Google shows me other people in Infinit0's situation simply using ASIO4ALL. I have no idea of the relative benefits of ASIO4ALL versus Wasapi Exclusive.
ASIO: app ASIO -> vendor ASIO driver
ASIO4ALL: app ASIO -> ASIO4ALL -> WDM -> windows audio mixer/layer -> stock driver
WASAPI shared: app WASAPI shared -> windows audio mixer/layer -> stock driver
WASAPI excl: app WASAPI excl -> stock driver
WASAPI excl is comparable to single-client ASIO, but uses stock drivers. E.g. MS Intel-HDA driver for the Realtek, or MS USB UAC2 driver for UAC2-compliant devices.
Details of FlexASIO bridge (similar in operation to ASIO4All) https://github.com/dechamps/FlexASIO/blob/master/BACKENDS.md#flexasio-backends , authored by windows audio guru @edechamps
Motu M2 or M4 (the M4 has a better ADC)
It's not a debate about quality. For downscaling purposes, I personally tried using WASAPI excl, FlexAsio, Asio4All, but nothing works flawlessly like native Asio. If your usage case does not involve MIDI instrument performance and DAWs that's a different situation.
I know, I am giving the chain comparison to show the latency potential.
That's why I linked the post by a Wasapi excl. user who has the same usecase as you - MIDI keyboard - > sw synthesizer -> audio output.
What issues specifically did you have with Wasapi exclusive?
That's incorrect. ASIO4ALL uses WDM/KS internally. On Vista+, WDM/KS does not go through the Windows mixer - it goes to the WDM audio driver directly.
Technically these go through WDM/KS internally just before they reach the driver, but I guess that's a detail.
Etienne, thanks a lot for entering the discussion.
Thanks for the correction. I could not google out what backend Asio4All uses. How do you determine this info? I use linux where the sound layers offer lots of troubleshooting tools/support, but do not know how to get deeper in windows.
IIUC WDM/KS is the API for the actual drivers (i.e. interface to the "stock driver").
My list was made from the latency POW. I wanted to show that your FlexASIO or ASIO4ALL along with Wasapi shared involve additional buffers (e.g. IIUC https://github.com/dechamps/FlexASI.../src/flexasio/FlexASIO/flexasio.cpp#L221-L234 ), unlike ASIO and Wasapi Exclusive which operate directly with driver buffers (analogy to device hw in linux alsa). Please correct me if wrong.
ASIO4ALL does not really mention WDM/KS explicitly anywhere (that I can find), but it does have docs that only make sense if it uses WDM/KS directly, such as this page about WaveRT for example (WaveRT is a WDM/KS concept and is meaningless anywhere else).
I just bought a Jcally JM12 for US$3 delivered and flashed it with the Fiio JA11 firmware.
Haven't tested it much yet but it has proper ASIO drivers and I can play windows audio while Ableton is using the ASIO.
