Thank you for the clarification. So, the unit could potentially have a great DAC but a poor/noisy amp? All the Behringer specs say is that it has "Powerful Phones output with Level control".Amir was measuring the Behringer's performance as a DAC. If you are using it to drive headphones, there are some additional considerations. How well implemented is that headphone amp functionality? How well can it drive the headphones that you use?
I'd avoid the older models that are limited to 48 kHz. I have an old Behringer UCA202 DAC that is limited to 44.1/48 kHz. It does not use async mode for USB audio output. Performance is mediocre at best.
Both of the main headphones I use are around 60 Ohms impedence. Would that be considered hard to drive? I know my cell phone can drive them, at least at the low volume levels that I generally listen at. I looked up more information on impedence as it relates to headphones. According to what I read, the impedence of the amp is important too and it should have significantly lower impedence than your headphones. The Behringer specs don't list that though.
