Budget DAC Review and Measurements: Behringer UCA222
I question whether the measurable improvement from this mod is audible, especially given how cheap the product is and the fact that it is not likely to be used for critical music listening in a system with extended bass response.
Fair disclaimer, I have been modding UCA202 / UCA222 since NwAvGuy's blog posts back in 2011, so I have a lot of experience with these interfaces and am obviously biased towards enjoying them. It is a cheap interface, but it is quite good when this issue is resolved. For many years I would use the interface with an ADUM3160 isolator and definitely felt that made an audible improvement, but it's not really necessary to use the isolator with this mod.
I almost wonder if Behringer intentionally hamstrung it by choosing to use such a poor voltage reference, so that it doesn't interfere with sales of their nicer interfaces.
So, I do have some bias, but I think the difference is audible with this mod. And i think the result is better than the old method of installing much larger output filter capacitors and using with a USB isolator.
Would definitely recommend it to anyone who has one of these lying around, listen to a song you know well before and after modding
Sorry, this is ASR not Youtube, so: not good enough.
Although I acknowledge what's apparently honest testimony, I still don't see much point in investing more in a couple of parts -- which tend to be absurdly pricey in tiny quantities -- and DIY time than the price of product itself when it goes on sale. By all means go for it if you think you'll enjoy the DIY effort -- I might try it myself just for $hits and giggles -- but IMO the ROI just isn't there given the typical use case for such a bare bones, "entry level" audio interface.
just out of curiosity - can anyone assist in identifying whether this is the "better sounding" UCA202 ? bought it over 10 years ago, no serial number, no date number.
Hello everyone.
I'm looking for an ADC which converts analogue L&R RCAs to USB for the purposes of making digital recordings of analogue sources.
I believe this does the trick, to be used in conjunction with Audacity.
Firstly, can anyone confirm that's correct.
Secondly, can anyone confirm if there's something like this, but better. Budget 'up to' £150, but preferably less. Plug and play.
Many thanks.
Hello everyone.
Many thanks.
I would suggest MINIDSP POCKETADC, it's well in your budget, not USB though.
You could use it no problem though for this purpose.
Thanks. Yes, I’m aware of that. But I definitely need USB. Would I be able to use the MiniDSP with an optical-to-USB adapter?
Yes, you would, but why? Just find an old PC with optical in and you'll go noise-free and perfectly digital in Audacity.
Easier said than done - optical in is fairly rare on PCs. Optical in on USB adapters is a lot easier to find.
It's often there, just not exposed, just need a bracket or something usually hidden with the rest of motherboard's stuff (if you build it yourself) .
And not only in but out too, same with coax.
Some Mac also has it but it's hidden and needs an adapter.
Edit: an example with my old machine:
The actual back I/O connections
C and D are only outs.
...while internally:
(bracket was in motherboard's box)
With my limited skills and knowledge, £20 or so for an adapter is a safer bet.
Many thanks for your help and advice.
In my experience it's occasionally there, but usually not. I've only had one PC with a toslink input, and that's a micro PC with combined analog/mini-toslink 1/8" sockets for input and output. Toslink and/or coax output is a lot more common.
I do not think the headphones out was even a priority when they designed this audio interface. Headphones out looks like an after thought by design, just rudimentary signal monitor in this gear. But many folks are fixated on the fact - it has headphones out, as they are looking for DAC with headphone amp on the cheap. So no testing was done for main objective of this interface: RCA in/out, figures. I think it would be perfect IO for tape decks calibration with NAK-T100.
Yours has the better Burr-Brown PCM2902 codec as in nwavguy's measurements, not the worse Coolaudio generic part amirm's example had.
I have an UFO202 date code1006 and an UCA202 date code 0905, both with PCM2902.
I went and did it. The low end is now audibly smoother with well recorded music, but not by all that much. It's probably not worth the effort other than in an unlikely situation in which you're using this dirt-cheap gadget for serious listening to excellent source media via first-rate transducers -- or if, like Frank, you want to use it as part of a measurement setup.
