- Thread Starter
- #21
Thank you for detailed answer.First off: placing the speakers high up isn't the real issue for your soundstage.
The actual bottleneck here is your extremely short 70cm listening distance.
You mentioned being worried about losing the soundstage when moving your head 50–60 cm.
It's a timing issue, not a directivity issue: When you sit that close (70cm), moving your head even 20–30 cm to the side drastically changes the time it takes for the sound to reach your left vs. right ear. The speaker you move closer to will sound louder and arrive earlier, which breaks the phantom center effect = soundstage effect. A coax speaker won't fix this. This breakdown happens at short distances purely due to arrival time, no matter the speaker design.
Keep in mind that the stereo image and soundstage will always play out on a direct line between the two tweeters. Since your speakers are 50cm higher than your ears, your soundstage is also up there. If you're cool with that acoustically, go for it.
While coax options like the KEF Eggs or Tannoy Arenas sound great on paper as point-sources, a traditional 2-way design is almost always the better choice in this budget tier:
Coax drivers in budget setups usually lack cabinet volume and cone area. Standard 2-way speakers will give you much better extension down to your crossover point.
Designing a good coax driver is expensive. At lower price points, a 2-way speaker will simply give you better component quality and cleaner overall sound for the same budget.
Since you have to mount them high, place the 2-way speakers upside down (tweeters on the bottom, woofers on top) and just above the monitors. This gets the tweeters as close to your actual ear level as possible. Your brain can't easily localize low frequencies anyway, so it doesn't matter that the woofers are up top. Tilt them down 30 degrees to aim the tweeters right at your ears.
Look at the Kali Audio LP-6 v2. They have a decent waveguide that gives you a much wider, more forgiving sweet spot (in this case, sweet spot means the area before the frequency response changes much, not the area of the phantom effect). Plus, they have dip-switches on the back specifically designed to correct the EQ when you place speakers in weird positions (like high up on a wall or desk shelf).
Or check out these recommendations (best speaker for different budgets). https://www.audiosciencereview.com/...-recommendations-for-usa-by-sweetchaos.28269/
For my budget I can only get:
kef egg 1st gen - actually the cheapest way for uni-q drivers, 2nd hand about $100
moondrop mm3a
Jbl 104
some edifier's, mr3 etc..(don't like them)
