marcheloka
- Joined
- Jul 8, 2024
- Messages
- 22
- Likes
- 2
Hello guys ive got a couple newbie questions for you. Would be very grateful for your insights.
1. Do you think it would work to setup budget HTPC with active monitors? Ive got lots of movie rips and watch them often and also watch live streams / sport events streams on my Windows pc.
2. Ive already found the way to setup it up the most simple budget way possible: my pc - > USB - > external sound card - > 3 stereo jacks - > 3x2=6 separate channels to use.
Ive already bought some cheapo sound card and it is working - https://amzn.eu/d/0iALRHEh
Is it degrading my sound quality and how much? What would be a step up in the sound quality?
3. Ive only tried it couple if times with some 2 pairs of speakers so 4.0 but i think it would work with 4.1 or 5.1 as well. So i need to take Care of proper wires for the proper setup. So is 2x0,18mm shielded okay? From what ive found out you can weld the balanced like trs or xlr to Such shielded wire or you can weld the unbalanced ts or rca as well? Can i bury proper cables under the flooring and give them unbalanced as for now, but if later i cgange my mind to balanced i just cgange the plugs yea? I was thinking about cord which is shielded and 2 like that https://allegro.pl/oferta/przewod-bit-liycy-2x0-75-sterowniczy-2x0-75-na-metry-15623390969
4. So we get to 4.1. My projector give me big screen basically to the floor so no room for center speaker. Or it would need to lay right there in the floor. Is it a good idea? Sound from below, and floor reflections i dont know. Is the phantom center a good idea? Is there a way to turn it on using Windows?
