TheKaosDome
- Joined
- Jul 24, 2024
- Messages
- 14
- Likes
- 3
Hey all
I hope you all doing well.
If this is posted in the wrong section, my apologies. (mods please move as needed)
So I am in the process of building my first 2.1 system. I was using the Corsair SP2500, but they are no more. (I know they aren't great speakers, but for "computer" speakers they were ok)
Currently I will be using an ifi Zen Dac V2 leading into either a FOSI BT30D Pro or I can use the DA2120C.
How do you guys feel about TAS5352A vs TPA3255.
I am currently using the 8" sub from the 2.1 I had as a passive sub. (120W RMS, 8", in 4th order bandpass enclosure) but would like to pair it up with some floorstanders.
The room I am using them in is tiled and has dimensions: +-30m2 (double car garage converted to listening room)
These are the floorstanders currently available with my local suppliers in no specific order. (based in South Africa)
MONITOR AUDIO BRONZE 200
Fyne F303
Yamaha NS-777 (Maxing the budget)
POLK MONITOR XT70
Klipsch R600F (Maxing budget, but currently on special)
DALI OBERON 7 (Maxing budget, but currently on special)
Bentley Acoustics FS-150
I was looking at getting the Fyne F303, they seem to have good base extension and good reviews, but some have said they are picky with amps.
I am open to all advise since I am terribly new to this.
Regards
Fyne F303
POLK MONITOR XT70
Regards
