Actually they said so in the power amp modules datasheet too, and I believe I posted that part, but will double check later. The clearly stated the amp modules are rated 700 w peak output, never claimed it was continuous.They didn’t say that for the amplifier. They said for the SMPS. Their amplifiers can deliver the rated power if you can cool them. It’s their power supply that is limited. It’s also the power supply that failed in this test.
It’s Hypex’s confusing specs that cause the issue. They do not offer a full amplifier spec.
Have a dance party and see…One question remains for me: It possible that an home user produce the same disaster as happened on the test bench with a musical program?
I see "guarded @ 27 amps" but also "Do not exceed or there will be damage" so not sure how it works but to me the 27 amp limit is a limit to prevent fires but not nessisarily save the PS but I could be wrong.On the contrary,as I posted a little earlier in the tread (just a few posts above the one you quoted) current is stated as "guarded" (see the screenshot).
I can't think of a stronger expression to state a condition of safety (the lamp when we first test a diy amp does exactly that) but then again English is not one of my languages.
Edit:link to screenshot
These are the NCx500 limits...They said the SMPS will fail if limits are breached. See their notice at the top.
We've done a lot of testing with these modules. It makes a difference if you mount the Hypex power supply on a 3mm thick aluminium baseplate or 10mm aluminium baseplate. When you provide a better passive or active cooling to these modules, they will output higher continuous power. It is the amplifier modules that generate the most heat. The transistors are mounted on the bottom of the amplifier module. So mounting this module to a 10mm aluminium plate or heatsink will result in a lot higher continuous power than when mounted on a 3mm thick aluminium plate for instance. So the continuous power depends on how the manufacturer implements these modules in their design.They didn’t say that for the amplifier. They said for the SMPS. Their amplifiers can deliver the rated power if you can cool them. It’s their power supply that is limited. It’s also the power supply that failed in this test.
Hypex stated clearly that the 700 W rating was not continuous. Regarless, there are very few manufacturers that specify continuous power output that is continuous indefinitely. Most of them, use that term without clearly stating the condition/duration. Do you have an amp that actually say what its literally continuous, non stop output rating is? Again, there are some, but very few that I am aware of.
Self guarded by the module?These are the NCx500 limits...
That's the same datasheet I referred to, in which it specified the 700 W as "Peak" and under the "Continuous" rating space was left blank, with note 1:BUCKEYEAMPS Hypex NCx500 Amplifier 2channel Review
It could be interesting to know how long it was demanded to this amp to run over 100W continuously, If it had been running above 325W more than 10 sec, if proper cooling time was done in between tests. Again not that he should have, but good info to assess I agree. That is a fair question...www.audiosciencereview.com
Keep in mind with music power the dynamic peaks are so fast the PSU won't be so taxed.thanks for your effort! This papaer shows very detail measurement... so amazing.
I believe the company can make enhanced amplifier with appropriate psu.
Not that easy. Read heading 8.That's the same datasheet I referred to, in which it specified the 700 W as "Peak" and under the "Continuous" rating space was left blank, with note 1:
So, Hypex did not specify a continuous rating, period. It will be up to the builder to implement their "thermal system" and then they could provide the continuous rating. And they why I suggested what buckeyeamp should do, in regard to their specs.
I know that Buckeye advertises their new PSU contracted from Micro Audio has this capability:
He doesn’t mention if he will use this SMPS on his stereo/mono options, but I assume he would.
@MicroAudio this is outside the scope of this thread, but I would appreciate it if you could talk about your PSU’s PFC and the benefits it might bring to consumers audio solutions?
There is a spec sheet on the exact same page you linked. It may be time for a break now.
Apologies if I am misunderstanding as I'm a total layman, but is this effectively saying the maximum continuous power (presumably for any length of time longer than 10 secs) one can safely achieve from the supply, assuming a sufficient cooling solution (i.e not exceeding 95 celsius), is 325W across both channels? Not a problem in real world usage at all but definitely worth knowing for test cases such as this?
It assumes a continuous to peak power ratio of 1/8, Imho a conservative enough figure for any musical program.Apologies if I am misunderstanding as I'm a total layman, but is this effectively saying the maximum continuous power (presumably for any length of time longer than 10 secs) one can safely achieve from the supply, assuming a sufficient cooling solution (i.e not exceeding 95 celsius), is 325W across both channels? Not a problem in real world usage at all but definitely worth knowing for test cases such as this?
My interpretation was that with sufficient cooling it can maintain max output not "steady" output. But that requires the system integrator to do additional work to maintain the temperature. The board itself is guaranteed for 10s without any additional thermal work by the integrator.Apologies if I am misunderstanding as I'm a total layman, but is this effectively saying the maximum continuous power (presumably for any length of time longer than 10 secs) one can safely achieve from the supply, assuming a sufficient cooling solution (i.e not exceeding 95 celsius), is 325W across both channels? Not a problem in real world usage at all but definitely worth knowing for test cases such as this?
Is this effectively saying the maximum continuous power (presumably for any length of time longer than 10 secs) one can safely achieve from the supply, assuming a sufficient cooling solution (i.e not exceeding 95 celsius), is 325W across both channels? Not a problem in real world usage at all but definitely worth knowing for test cases such as this?
