It bears to say that the limiting factor with these new Purifi amps will be the buffer board. The excellent datasheet specs of the 9040BA for example where sourced by a truly reference source, the AP measurement system which is ultra noise free and superb in every way. Costs more than $50K plus options.
Our usual OP1612 or Weiss OP base buffer or Sparkos, etc are not AP quality, ofcourse, so they will be the great limiting factor. The Purifi module has a THD+N less than -130dB or better per its datasheet. With these buffer boards, based on their design, layout and shielding, expect that spec to drop by more than 10dB to -110 or worse as a realistic spec.
This does not take into account the style of wiring inside the amp case. Are the high current/high voltage/high slew rate wires just casually passing over the sensitive buffer board? If so, expect a significant noise penalty. Are these wires twisted or not? If not, looking at you VTV amplifiers, radiated EMI bleeds into the audio buffer to raise distortion even further. Let's not forget radiated emissions from an unshielded and/or poorly placed switch mode power supply.
Lastly, the 9040BA has a rated 4.5uV noise floor and a 14.4dB gain. A buffer's output noise scales with its gain, so to get the typical 26dB total gain, like analog amplifiers, the buffers gain stage will gain up its output noise by 12dB, not including the voltage and current noise contribution of its gain resistors and the opamp itself, etc
Anyways, by the time you figure out all these things, the final noise penalty will be severe. March Audio specs a THD+N or -115dB (0.00017%) to -119dB (0.00012%), depending on output power level for their P801 9040 based mono amp. It has an SNR of -136dB (!) per the website verses the -140dB of the 9040BA module
. This is excellent and superb and probably the best out there.
Even specs from another 9040 amp from
Cymax, amp with crazy shielding has a -106dB THD+N spec (0.0005%) and an SNR of 118dB, despite having an ultra low noise Weiss OP opamp (see last page of user attached datasheet).
Lesser capable vendors amplifiers will produce worse specifications than March Audio. We should demand vendors to publish measured specs of their amplifiers as a complete system and not claim those of the Purifi modules alone.
