EJ3
It's fairly simple: either you can operated the whole item at full capacity all at once or you cannot. It costs more for testing on 8 channels running and/or 220-240 volts because it involves more. More channels tested at once (for the same parameters) costs more. You want more: you pay more.Hard to compare as 8 channels vs 2. So price cannot indicate what the extra costs for extended testing are.
In the USA that may require you to be able to have 2 plugs in 2 separate circuits, dedicated higher amperage circuits (such as every outlet in my home is a 20 AMP or more outlet to circuit breaker on the service panel [don't know why, it was that way when I moved in] with 2 separate outlet/circuits near each other in the living room, perfect for my Tri-Amped system or perhaps a dedicated 240 circuit {yes, the US is actually on a 220 system, it just gets split up into 120 with a couple of 240's at the home}. There may be issues with 50 vs 60 cycles but 120 vs 240 (220) is not an issue that is difficult to solve. Most homes have some 220-240 circuits already for electric ranges & electric dryers for laundry already and it's not usually not that difficult to run a 220-240 circuit to another part of the house.
Like many (though not all) Epic pressings of its era, at least the copy I have is crispy-bright sounding (not a great sounding record). She would leave, rather unceremoniously, whenever it was on the turntable.
