I have measured maximum power of the 1ET400A, with SMPS400A180 power supply (2x46V), in the 20Hz - 20kHz range, for THD and THD+N <= 1% and at least 10s duration at each measured frequency. This is the result:
The high feedback used in these designs not only reduces distortion in general but also reduces the effect of power supply fluctuations.
As we all know Class D gain depends on the supply voltage. Some have suggested it might be used as a volume control for open loop, zero feedback, designs because that's nice.
Whilst measurement bandwidth limitations have been mentioned, and countered, I wonder if the rise in output power with frequency might be due to loop performance of the SMPS or more specifically filtering on the board itself.
In the first instance bandwidth of an SMPS is limited so it may not be good at controlling high frequency demand. AHA! you say Capacitors. Indeed that might be the reason. At higher demand frequencies the capacitors take over, the supply ripple goes down so the distortion goes down letting you draw more power before hitting your 1% limit.
But.... With apologies for linking to another Purifi Product.
I recently reviewed the NAD M28 multichannel amplifier based on Purifi modules. As promised, this is a tear down of the unit with kind permission of the owner. The amp was a delight to open with beautiful screws holding the attractive top down. Once removed, we are greeted to a nice and...
www.audiosciencereview.com
Spot the two thick wire rod inductors to the right of the main output inductor. On the right of them are a bunch of local filtering electrolytics. This appears to be a standard feature of Purifi Modules.
There is a thing with Switch Mode Power Supplies, a Class D amplifier is an SMPS...
ridleyengineering.com
They interact with their inputs. Middlebrook deals with input filters but I would not be surprised if the same applies to an input SMPS supply that has its own frequency dependencies.
As a result my own wet finger would suggest that Purifi include these inductors on the board, along with the on board electrolytics, in order to isolate the amplifier from the connected supply and keep the amplifier happy whilst allowing the module to be used with a range of disparate supplies.
Perhaps these were the wrong inductors that were fitted?
In terms of the power going up with frequency in order to hit a specific THD again I am going to suggest it is down to ripple on the capacitors but with this input filter the SMPS is not important. Yes it may give you long term grunt but that filter limits the overall supply HF performance.
Should you wish to check my blither then it might be worth having a look at the HF ripple on the supply post that local filter.
Either way I think that supply ripple as reduced by capacitance may, outside of regulation, be the reason why you can get higher power out with THD as the limit.
Don't forget the important side of the coin is that that filter on the board itself will, by and large, determine the limit. Whacking more capacitance on your SMPS is likely to be a waste of time.
