Sokel
- Joined
- Sep 8, 2021
- Messages
- 11,213
- Likes
- 12,177
There's another good reason for skipping the latch, and that is having "sensitive" output gear upstream, a blind connection and one can easily short this outputs if latch is of the generous kind.We specifically choose the Neutrik spring loaded connectors over the traditional latch ones for a specific reason: in the rare event that the latch fails on an XLR connector, it can be a tedious/non-straightforward task to remove the XLR cable as it can become stuck. Whereas with the spring loaded, if it ever breaks the connector can still be used without issue (the cable doesn't become stuck).
But generally yes, latch smells pro stuff, if one is used to it...
