Buckeye PURIFI 1ET9040BA Amp Review
Rate this amplifier:
    Votes: 4 1.1%
    Votes: 0 0.0%
    Votes: 28 7.6%
    Votes: 337 91.3%
I would order mine in the rack mount case, so none of them would bother me.
It's only a relatively recent addition to the test schedule, so there are few amps to compare.
Personally, I've long thought the NCx500 doesn't have any shortcomings in any respect.
I wouldn't think there would be any shortcomings. I was just curious.
I've got two ncx 500 dual mono amps in my house. I love them. I run them at 4 ohm I can't see any reason to upgrade to the purifi.
Can someone explain to me either the colors or blinking pattern of the LED used to signify clipping or fault? Or any other information the LED can convey? Thanks!
A single LED indicates On/Active (blue), clipping (orange) or fault (red).
I was curious on your graph for power output at 40 HZ you didn't have any of the hypex ncx500 amps.
Would you happen to know what the hypex ncx500 mono was doing at 40 HZ power wise into 4 ohm
Not 40 Hz unfortunately, but we have 20 Hz here and it's pretty close (-40 dB = 1%), so 40 Hz must also be around 600 W into 4 ohms.
I tested my 2ch NCx500 amp into a 4ohm resistive load at 40hz and got 430w both channels driven. The measurement was taken just before the negative sinewave started to show clipping on the o-scope. If I pushed it further so the positive sinewave also showed clipping, I measured 529w. Both channels measured this way.
What would you suggest as a preamp and DAC that is NOT a Wiim to use with a pair of Buckeye Monoblocks?
Minidsp Flex Balanced is my usual.
The Buckeye 9040 amps will, likely as not, be paired with top of the range loudspeakers and it makes sense to drive them with a similarly high performance flexible preamp DAC from an established manufacturer. Relatively expensive but very capable are DACs from RME. The top of the range ADI 2/4 pro SE offers PEQ, tone controls, loudness, Sub woofer capability, ADC on analog input which also has an option for digital RIAA equalisation. Also comprehensive headphone outputs.
The Buckeye 9040 amps will, likely as not, be paired with top of the range loudspeakers........
That is a pity but you are probably right.
How nice that you're familiar with everybody's needs
I don't know why you keep generalizing about these amps as if they were mainstream mass-market products sold at Amazon or Brandsmart
These are niche products and they are not meant for 98% of the population
Most folks are happy with receivers purchased from Amazon or Best Buy and that's fine
My concern is that the 9040Ba will not be powerful enough to realize the full potential of my speakers
I would like for Purifi to develop a 750 watt (8 Ohms) Eigentakt amp
I have large speakers in a somewhat large room and I would like to light them up on occasion
Sorry if that interferes with your view of the world
At these prices, why not bi-amp sir.
In general passive bi-amping is worthless to most,, almost as bad as bi-wiring. With passive speakers just get the amp with enough headroom that you need. Now if you're doing an active speaker, that's where you need to divide the power between the drivers.
If I were to shell out for a set of these Monoblocks could I reasonably expect them to last the rest of my life? Or is that just not a thing with class D ? If not maybe getting a cheaper Stereo amp is the way to go.
