Sokel
- Joined
- Sep 8, 2021
- Messages
- 11,440
- Likes
- 12,563
And soundimports for simple modules in a decent small case.and Audiophonics in France (and Europe).
Yes, but I was limiting the list to those with good independent measurements.And soundimports for simple modules in a decent small case.
Thanks, missed that one!Also Boxem
At least until tariffs go away hopefully!It seems that the best "geographical" options are Buckeye in the US (and Canada?), Nord in the UK (and Europe), and Audiophonics in France (and Europe).
Good lord, people buy this crap? A far better space heater than amp it seems.
SCOTUS decision forthcoming any day now.At least until tariffs go away hopefully!
Top of the volume control provides the highest SNR specs for every amplifier, assuming we are still in linear operation (i.e., not clipping).There is no requirement that the top of the volume dial be able to deliver max power. In fact, often that is not desirable.
You can't go wrong buying a Buckeye Amp from Dylan. Great product and support. I wanted the Purifi 1ET6525SA for my secondary system but wanted monoblocks to put the Amps close to the speakers to minimize total impedance at the speaker input for maximum Damping factor. At the time this configuration was not listed on the web site but Dylan put together the monoblock configuration for me and it's now available as an option. I'm using KLH Model 5's in this setup and the 1ET6525SA's 230W @ 8 ohms is more than enough to drive the speakers to volume levels above comfortable listening levels without any audible distortion from the amplifier. A more affordable option if your speakers don't need the massive power output of the 1ET9040BA. BTW, my main system uses a Benchmark AHB2 (rated 100W per channel at 8) and it comfortably drives a pair of high end Revel's. More power is perhaps desirable but not always necessary.This is a review and detailed measurements of the Buckeye Purifi 1ET9040BA (second generation?) monoblock amplifier. It was kindly drop shipped by a company and costs US $1,295.
A single LED adorns the front indicating power on, protection or fault condition. Back panel has all that one would need for balanced operation:
Gain settings are well chosen and inclusion of trigger input for automatic turn on via the source is appreciated.
Buckeye Purifi 1ET9040BA Amplifier Measurements
Let's start with the low gain setting and see what we get:
What we get is a big smile on my face!Distortion clocking below -130 dB which is hugely below threshold of hearing. Noise as a result sets SINAD to an excellent 110.6 dB, easily landing the unit in our top 20 amps:
Medium and high gain given you the ability to reach full power with more reasonable input voltages but costs you some SNR and hence SINAD:
Staying with low and medium gains, we see state of the art measurements at full power:
Vanishingly low distortion remains even at highest frequencies at 5 watts:
Class D amps can suffer from load dependency but not here:
Impedance does not change even up to 100 kHz measurement point!
Story gets even brighter when we consider how much power this lightweight and cool running amp can produce:
Company specs the amp at 2 ohm so I ran that test as well:
Wow!
Even into 8 ohm we have more power than many amps produce at 4 ohm:
Muscular power output extends down to 40 Hz, climbing to highest wattage I have measured:
Higher frequencies tend to give class D amps a hard time but not so much here:
Amp is very quiet on power on but may have some noise on power off:
And it is stable on power on:
Conventional wisdom says you can have lots of power or finesse. The Buckeye 1ET9040BA tears up that rule and flushes it down the toilet. It has incredibly low noise and distortion, especially at lower gain settings, but also produces copious amount of power, courtesy of its new power supply and capable Purifi amplifier modules. All this in a very cool running package, with features you want at a price that is hard to fathom just a few years ago.
It is my pleasure to recommend the Buckeye 1ET9040BA monoblock amplifier.
why?Was hoping for better result at 15kHz, l
that's the great part -- if you want to pay more for a case for something you never need to look at or touch, you can get that from somewhere else with the same hardware inside. For those who don't care what it looks like, it's an option to not pay for it.This BUCKEYE 9040 amp wins the ugliest design award by far. But, Purifi 9040 is certainly quality hardware.
I wonder what is causing the NINE evenly distributed 10-15dB distortion spikes in the 50 to 8KHz range? Any idea?
Likely not audible but NOT what I would expect from Purifi design team?
This is getting a bit nerdy, but I make no apologies. I'm having fun (though I'm mindful that somebody recently told me to get out more).Thanks Amir, I've been looking forwards to this review for some time.
The SINAD was a touch disappointing, but the HF linearity and load tolerance were brilliant.
This might go to set the highest ever vote.
Hi xaxxon. If you're referring to my post I'm using two monoblocks, one for each speaker.8 ohms "both channels driven" on a monoblock?
He's referring to Amir's Power vs Distortion graphs, eg:Hi xaxxon. If you're referring to my post I'm using two monoblocks, one for each speaker.
Can confirm and appreciate this - I was ready to spend the extra for three 9040s but Dylan indicated it would make essentially no difference driving a pair of 226Be and a 426be in a moderately sized room.Which is why I never upsell anyone who is looking at the 2ch options.
now we need it distilled into like WiiM Amp style devices with like 300W/channel for $500 or whatever. HDMI-in amps which can connect to the TV and use the TV remote, but with massive low impedance power. AND still low distortion and noise. It's the next frontier!, I agree that the amp question is a solved problem. Between the various Purifi and Hypex offerings, set your budget, determine power needs and figure out what looks good in you living room.
Don’t forget Apollon!It seems that the best "geographical" options are Buckeye in the US (and Canada?), Nord in the UK (and Europe), and Audiophonics in France (and Europe).
Seems nice as well. What does shipping/tariffs cost from Slovenia to USA? EU? Etc?Don’t forget Apollon!
Slovenia is part of the European Union. Tariffs 15%, shipping costs practically the same as those for audiophonics in France.Seems nice as well. What does shipping/tariffs cost from Slovenia to USA? EU? Etc?
