sceptical1
- Joined
- Mar 10, 2025
- Messages
- 181
- Likes
- 162
Here it is:
That's not a noise chart alone, it's THD+N, so distortion plus noise, you can't tell the noise alone from that.Here it is:
No, We can all see the measurements - and as has been pointed out, you've chosen the wrong one.Here it is:
Deep dives into parts costs rarely avoid political commentary.
Just deleted a few posts that started down this path. ASR members are supposed to avoid politics. Please keep to product feature and performance discussion here.
PLEASE NOTE THE ABOVE POST. Not going to allow tariff or related discussion here either.
Just culled several posts after a report of speculative political commentary. Hopefully will not need any more deletions or otherwise you may get a warning and/or a thread ban next.![]()
The performance ceiling of these Purifi amps is very very high. While all of the integrators make audibly perfect amps, the high performance does make the integration important.
Purifi modules have low gain and low input impedance. Therefore the integrators use input buffers ahead of the Purifi modules. Different integrators have used different input buffers. These input stages need to operate at very high SINAD while providing most of the amps gain.
While not the same difficulty as designing the Purifi modules, the integrators do need to make sure to get a lot right in their implementations because the smallest EMI, cable resistances or grounding problems is a big degradation from 110 dB+ SINADs.
"... have no audible distortion ..."These amps have no distortion. What is shown there is close to 100% noise.
Thank you, @Buckeye Amps, to ask, no allowance for SE/RCA input which suggests that SE/RCA input is not recommended, is that correct? If SE input is also recommended can you clarify.
Are there consumer amps with 1400w at 4ohms with less than 4db noise? (And are they $1300?)
I have a WiiM Pro Plus connected directly (with RCA to XLR cables) to a Hypex Nilai stereo, on medium gain (+21.8dB). I initially tried it on low gain (+11.8dB), but decided it was a little anaemic, although that's probably because I was being overcautious with the volume. Medium gain is plenty loud enough, however!I have a very beginner question. Please pardon my ignorance. Is it okay to use wiim ultra directly connected this amp with a low gain setting? Wimm ultra rca vrm is only 2.1 and the spec sheet says 8ohm low gain needs 7.1.
Offering these external 14dB-ish low-gain options is meaningless. You essentially bypass the buffer module and go straight to the purify amp, which all by itself has an internal gain of 14.4dB. You'll need a source capable of 10.5 Vrms output to reach the full power of this module, and there are very, very few preamps capable of that kind of output.I have a WiiM Pro Plus connected directly (with RCA to XLR cables) to a Hypex Nilai stereo, on medium gain (+21.8dB). I initially tried it on low gain (+11.8dB), but decided it was a little anaemic, although that's probably because I was being overcautious with the volume. Medium gain is plenty loud enough, however!
This amp's low gain setting is +15.6dB, so unless you want to play really loud, I'm sure you'll be fine.
Alex
Our reasoning for offering essentially a "bypass" option using low gain had zero to do with SNR measurement and everything to do with feedback/input for those very few people out there who would like to use such low gain.Manufacturers offer this option because it generates the highest SNR, and that looks good from a marketing perspective. But very impractical in real life.
There are people who like the other aspects of the Purifi (low noise, inaudible distortion, highly efficent, technological approach, etc.) and who like the idea of ‘limitless power’ but have sensitive speakers and modest/safe SPL levels. Those people may want to run their DACs and preamps near the peak of their output to get best performance and thus pick low gain.You'll need a source capable of 10.5 Vrms output to reach the full power of this module
Never said I had issues with power at all. Make a 1400W amp or a 3500W amp. All is good. I, myself, would buy a 2000W amp if it's super quiet and has low THD specs, much like the 9040BA module.There are people who like the other aspects of the Purifi (low noise, inaudible distortion, highly efficent, technological approach, etc.) and who like the idea of ‘limitless power’ but have sensitive speakers and modest/safe SPL levels. Those people may want to run their DACs and preamps near the peak of their output to get best performance and thus pick low gain.
For many people the point of Purifi is to have overkill. The SNR is way below audible. The distortion is way below audible. But the power being way above any practical need is the one thing that bugs you as overkill?
I appreciate your genuine response, @Buckeye Amps. Now, you may or may not want to answer this question, and it is perfectly understandable if you choose not to...Our reasoning for offering essentially a "bypass" option using low gain had zero to do with SNR measurement and everything to do with feedback/input for those very few people out there who would like to use such low gain.
Can't speak for others and I certainly won't pretend to guess their motives.
It isn't a bypass as there is still a small amount of gain being applied at the low setting. But if a user really wants a full bypass option we can do that too.I appreciate your genuine response, @Buckeye Amps. Now, you may or may not want to answer this question, and it is perfectly understandable if you choose not to...
Is your bypass gain path a direct-to-module pathway into the low input impedance of the module, or is it via a low-noise unity-gain buffer to present a lower impedance to the module? I think the latter, but only you know.
But you don’t get the cool vu meters an blue lights!Just love seeing such a relatively small thing being able to produce that kind of power. Compare that to those huge (and stupidly expensive) audiophile things like a McIntotosh this is really nice to see!
