Buckeye PURIFI 1ET9040BA Amp Review
Rate this amplifier:
    Votes: 5 1.3%
    Votes: 0 0.0%
    Votes: 29 7.4%
    Votes: 358 91.3%
This is a review and detailed measurements of the Buckeye Purifi 1ET9040BA (second generation?) monoblock amplifier. It was kindly drop shipped by a company and costs US $1,295.
A single LED adorns the front indicating power on, protection or fault condition. Back panel has all that one would need for balanced operation:
Gain settings are well chosen and inclusion of trigger input for automatic turn on via the source is appreciated.
Buckeye Purifi 1ET9040BA Amplifier Measurements
Let's start with the low gain setting and see what we get:
Buckeye PURIFI 1ET9040BA monoblock class D amplifier Low Gain measurement.png
What we get is a big smile on my face! :) Distortion clocking below -130 dB which is hugely below threshold of hearing. Noise as a result sets SINAD to an excellent 110.6 dB, easily landing the unit in our top 20 amps:
Medium and high gain given you the ability to reach full power with more reasonable input voltages but costs you some SNR and hence SINAD:
Buckeye PURIFI 1ET9040BA monoblock class D amplifier Medium Gain measurement.png
Buckeye PURIFI 1ET9040BA monoblock class D amplifier High Gain measurement.png
Staying with low and medium gains, we see state of the art measurements at full power:
Buckeye PURIFI 1ET9040BA monoblock class D amplifier SNR Low Gain measurement.png
Buckeye PURIFI 1ET9040BA monoblock class D amplifier SNR Medium Gain measurement.png
Vanishingly low distortion remains even at highest frequencies at 5 watts:
Buckeye PURIFI 1ET9040BA monoblock class D amplifier Low Gain Multitone measurement.png
Buckeye PURIFI 1ET9040BA monoblock class D amplifier Low Gain stereophile 19 20 kHz intermodul...png
Class D amps can suffer from load dependency but not here:
Buckeye PURIFI 1ET9040BA monoblock class D amplifier frequency response Low Gain measurement.png
Impedance does not change even up to 100 kHz measurement point!
Story gets even brighter when we consider how much power this lightweight and cool running amp can produce:
Buckeye PURIFI 1ET9040BA monoblock class D amplifier Low Gain Power 4 ohm measurement.png
Buckeye PURIFI 1ET9040BA monoblock class D amplifier Low Gain Power 4 ohm max and peak measure...png
Company specs the amp at 2 ohm so I ran that test as well:
Buckeye PURIFI 1ET9040BA monoblock class D amplifier Low Gain Power 2 ohm max measurement.png
Wow!
Even into 8 ohm we have more power than many amps produce at 4 ohm:
Buckeye PURIFI 1ET9040BA monoblock class D amplifier Low Gain Power 8 ohm measurement.png
Muscular power output extends down to 40 Hz, climbing to highest wattage I have measured:
Higher frequencies tend to give class D amps a hard time but not so much here:
Buckeye PURIFI 1ET9040BA monoblock class D amplifier Low Gain Power 4 ohm vs frequency vs dist...png
Amp is very quiet on power on but may have some noise on power off:
Buckeye PURIFI 1ET9040BA monoblock class D amplifier Low Gain power on off noise pop static me...png
And it is stable on power on:
Buckeye PURIFI 1ET9040BA monoblock class D amplifier warm up measurement.png
Conventional wisdom says you can have lots of power or finesse. The Buckeye 1ET9040BA tears up that rule and flushes it down the toilet. It has incredibly low noise and distortion, especially at lower gain settings, but also produces copious amount of power, courtesy of its new power supply and capable Purifi amplifier modules. All this in a very cool running package, with features you want at a price that is hard to fathom just a few years ago.
It is my pleasure to recommend the Buckeye 1ET9040BA monoblock amplifier.
  • Buckeye PURIFI 1ET9040BA monoblock class D amplifier Low Gain Power 4 ohm vs frequency vs dist...png
Nice, thanks for testing and to @Buckeye Amps for sending this amp in. Great results, exceptional power.
Pic from the Buckeye site;
JSmith
Incredible, no-compromise amp! Even the higher price doesn’t seem all that excessive.
Thanks @amirm!
PS. did you mean to put 4 Ohm Power vs. distortion (bandwith) graph twice?
Fantastic review, thank you! I noticed a typo: "with the lose gain setting" I think this should be "with the lowest gain setting"
Wow! $2600 is a lot to pay for a pair of mono blocks these days but for a Purifi amp that can put 382 WPC into 8 ohms and be so load indifferent as to deliver 1.4kw into 2 ohms and just smile, it's worth every pfennig. If I ever break down and cash out enough of my 401k to put a pair of Blade 2 Metas in my living room, I know which amp I'll be pairing with them.
Thanks for this one, Amir.
Wow, now this is what state of the art measures like! What a beast of an amp.
Was hoping for better result at 15kHz, looks like around -85/90dB seems to be the limit of what is achievable in Class D.
No need to remind me it is not audible, but still …
Quite some improvement in measurements vs 1et7040 module, so good.
I have 2 of those and could not be more satisfied, they are driving my electrostats without any issue.
Superb performance, but the price is prohibitive in my opinion, especially for a mono bloc....
As for the design, you either love it or you hate it.
BTW : I don't know if the choice of the Micro Audio SMPS1K-SN PSU was a deliberate one? I wonder what the results would be with the Hypex HYPEX SMPS1200A180 PSU.
About the Micro Audio PSU :
I consider this to be the best amplifier ever measured on this website, due to its exceptional watt-per-performance-per-price ratio. The 9040B is specifically designed to drive demanding 1-ohm and 2-ohm loads, which I think justifies its price point.
From the website.
Micro Audio SMPS upgrade:
In another partnership with Micro Audio, we are now using their new SMPS1k-SN power supply for the 1ET9040BA monoblock. Compared to the stock monoblock configuration most other competitors use (the Hypex SMPS1200A180), the Micro Audio SMPS upgrade brings with it Active Power Factor Correction (for better efficiency), better thermal management (for longer max continuous power output), and higher power output (from 1200w to 1400w into 2ohm).
The SMPS1K-SN PSU can do 4A continuous, 13A peak (@230V). The SMPS1200A180 datasheets don't really specify this. You could derive it from the power spec. of 1200W, which would mean about 13A max. But that's only in theory (for 46V output, and not accounting for potential losses) and doesn't give us the continuous output current capability.
Great amp.
Buckeye makes quality products. My only nitpick is their cabinets leave a bit to be desired. For that reason, I bought the prior generation, Purifi based Audiophonics amp (S400) several years ago that does everything I could ever ask of it.
As mentioned earlier, I agree that the amp question is a solved problem. Between the various Purifi and Hypex offerings, set your budget, determine power needs and figure out what looks good in you living room.
Focus your energy on other issues like speakers, sources and more importantly, discovering great tracks to listen to rather than how to tweak down distortion by another 0.01%.
