solderdude
6x600W from a socket is standard in my country and many other countries around the world. 230V/16A.
Indeed.
When playing music even with 6x600W peaks the average drawn current would be far, far below the 16A average.
So 15A per 125V plug.NEMA 5-15 grounded (Type B)[edit]
NEMA 5-15 plug, left. "Decora"-style duplex socket, with orientation as specified in NECA 130-2010, centre. Ordinary duplex socket, with orientation typically found, right. Photos are different scale – parallel blades are on 1/2-inch (12.7 mm) centres.
The NEMA 5-15 plug has two flat parallel blades like NEMA 1-15, and a ground (earth) pin.[39] It is rated 15 A at 125 volts. The ground pin is longer than the line and neutral blades, so the device is grounded before the power is connected. Both current-carrying blades on grounding plugs are normally narrow, since the ground pin enforces polarity. The National Electrical Contractors Association's National Electrical Installation Standards (NECA 130-2010) recommends that sockets are mounted with the ground hole up so that a falling object makes first contact with the ground pin.
This socket is recommended in IEC standard 60906-2 for 120-volt 60 Hz installations.
In many areas,[where?] tamper-resistant sockets are now required in new residential construction, with shutters to prevent contact by objects inserted into the socket.[40]
In stage lighting, this connector is sometimes known as PBG for Parallel Blade with Ground, Edison or Hubbell, the name of a common manufacturer.[41]
Listed as $1649 here:Is this for some home theater setups? That power looks off the charts high.
This amp seems really nice. Though those upside down connectors are weird. It wouldn't be so bad if they weren't locking (never understood the need for locking connectors in a home setup, but I guess folks like it?).
I presume the cost is under $2K for this?
www.audiosciencereview.com
In older houses with the original wiring and no dedicated circuit? The house I grew up in was built around 1960. In the 1970s, just using the room air conditioner would often trip the breaker (or, originally, blow the external fuse on the outside of the house, which caused my dad to curse a lot if it was raining or he was sleeping) during a Texas summer. There is no way this amp could have run off the same circuit when the A/C was on. We eventually added multiple air cons and switched the fuse box to a breaker box and had another circuit added. That included one that was 240v for the big AC in the living room, I believe. Then blow dryers became popular and we occasionally started blowing breakers again...As an electrician, I’d be pretty surprised if someone actually managed to trip a house breaker with one of these, but there’s firsts for everything.
As for the amplifier, these things are the bees knees. I use a 6 channel one he made for me that’s 2x500, 2x250 and 2x125 for my active 3 way fronts and it works perfectly and silently. No class AB transformer hum, no weight, much less heat, no power supply harmonics spraying across the FFT graphs, no hiss, no complaints.
Yup. Even them. So long as you don’t listen to sine waves or test the amp into load banks, I think you’d be fine.In older houses with the original wiring and no dedicated circuit?
If you ran 6 subwoofers you might get the fuse warm. That’d be how you’d do it if you were gonna do it.
Not really. It is one of the trade offs for the lower pricing. I'll never claim to have cases comparable to the other brands so I understand for some people it is a make or break consideration.Is there an option for a bit nicer enclosure?
