Buckeye NC252MP Stereo Amplifier Review
Rate this amplifier:
    Votes: 11 3.3%
    Votes: 22 6.6%
    Votes: 189 56.9%
    Votes: 110 33.1%
"Headroom" does not have a lot of meaning in this case if the Denon is truly limited to 1.6 Vrms maximum output, but I would guess its actual output is higher
HTH - Don
That first sentence is what I was wondering.
Thanks for links. I use that calculator all the time. I don't really need the extra power. I'm at at 101 dB. Do I need more? Probably not. Maybe with eq on some low sources/masters I'm pushing the V closer to the 1.6.
Will the 252 be sufficient to drive these ceiling Atmos speakers, or should I go for the 502?
I use them for my surrounds (8) with no issues. Good value for that.
Reactions: exm
I use the 252 to drive a pair of B&W AM1 outdoor speakers, which have a rated sensitivity of 86db, which is not very sensitive. They go very loud without any problems.
Reactions: exm
I now have Purifi amps powering them but when I first bought the Buckeye 252 I used it to power the Revel F208's and they were able to push the speakers to quite high sound levels. It would be difficult to determine which amp was running them unless they were both pushed to their limits then the Purifi would play cleaner at max dB.
PSA: if you [accidentally] tighten the panel-mount nut too much on the binding posts, you'll find that the binding posts are actually two different pieces. The threaded part for the nut is actually a stud that is press-fit, not that strongly, into a rear-facing hole of the larger outer part of the binding post. So basically as you tighten the nut, you are pulling the stud out of the binding post, and at some point it just does the bad thing :(
I'm trying to weigh my options around:
1a) Press the stud back in and be very gentle with the nut
1b) Press the stud back in and solder the two pieces together
2) Ask Mr. BA nicely for a replacement which may or may not be free, and which might not be any better
3) Get rid of the binding posts altogether and do a homemade speakON solution
The part that bothers me the most is that there's a fine line (for me, too fine) between not enough compression to keep the right-angle tab secure, especially against a quick-disconnect terminal, and just enough tension on the stud that the whole thing fails.
I was only nosing around inside just to make sure everything was kosher, and I started wiggling the terminals around and of course I made one come loose. Not knowing that the binding post could be damaged by slight over-tightening... =\
The part that bothers me the most is that there's a fine line (for me, too fine) between not enough tension to keep the right-angle tab secure, especially against a quick-disconnect terminal, and just enough tension that the whole thing fails.
Sending out replacement binding posts will not cost anything.
We no longer use this binding post (but have plenty of extras on hand). The press fit nature was a delicate dance of tightening to spec but not over tightening...and one of the reasons we upgraded to "higher quality" posts at a higher price (which wasn't passed on to customers of course).
Thanks for the quick response!
No need to send anything, I just hammered the stud back in and all should be well (at least for now).
Does anyone have an opinion as to whether I would hear any kind of sonic improvement by replacing my current amplifier, a Crown XLS 1502, with an amp that uses this same module, the Hypex NCore NC252MP?
The amp in question is the IOM Ultra, and I use the WiiM Ultra as my source/preamp. https://internetofmusic.nl/product/iom-ultra/
Aside from it looking cool, I was hoping for a sound improvement. My speakers are the Soundfield Audio M1V2, which use the Tang Band W6-2313 6" coaxial driver for the mids and highs (and an active 8" subwoofer on the bottom). The Tang Bands have a nominal impedance of 4 ohms.
Instead of posting about buying a different amp in this dedicated review thread, it may be better to start your own thread to ask.
Amir has reviewed the Crown XLS 1502 so you could compare measured data: https://www.audiosciencereview.com/...-and-measurements-of-crown-xls-1502-amp.6062/
The Crown has more power but higher noise (more hiss).
...will there be a noticeable improvement in sound quality compared to Niles SI 2150 with the Buckeye NC252MC...???...
...I finally replaced the Schiit stack with Topping D50III and SNSL H 400...
...the Schiit stack worked well but won't be missed...
...I am driving Elac Carina 243.3 speakers supplemented by a pair of SVS SB 2000's...
...one concern is how to connect the subs as I am not aware of any sub out on this equipment...that is one convenient feature of Niles SI 2150...
No
That's a good reason to continue using the Niles SI 2150.
...yeah, there are no binding posts on the SVS SB 2000...
...I had to get a funky BIC subwoofer for Adcom GFA 5500 because none of the cool new subs seem to have them...
...I talked to AI and it said to just use RCA out on H 400...if I run a balanced amp those outputs will be open...(D'OH!)
...now it's back to if it worth it...the most significant difference in the specs I can see is 96 vs 85 db SNR...
...not sure how noticeable that will be at my age (71)...
...nice map but the AI is stupid after all...LoL...it failed to account for the fact that the SMSL H 400 doesn't output to both XLR and RCA simultaneously...
...it looks like the Niles amp is staying in the chain...
@Buckeye Amps do you know if the latest NCx252MP or NC502MP version of this amp still have the on/off pop noise that the review unit in this thread has? I notice that the newer units have "Muted soft-start/shutdown" on the website but not sure about the review unit here. Thanks!
Seems we have the same "issue" with the Audiophonics one (based on NC252MP)
There is still a faint on/off pop. Nothing at all dangerous/harmful to the speakers and barely above background noise for the most part.
The cool thing about the Hypex nc252mp module is that it is very adaptable to a medium powered passive pre based stereo system. It has relatively high input impedance, sensitivity, and enough gain and power to drive a
reasonably efficient set of speakers to a comfortably loud volume. You can hardly go wrong with it.
The Buckeye version felt like a good choice because following his build thread here, Dylan seemed detail oriented and open to suggestions that some really knowledgeable people presented.
It’s been a couple of years now and using the amp with a WiiM Pro Plus as a source has been a positive experience.
