sam_adams
- Joined
- Dec 24, 2019
- Messages
- 998
- Likes
- 2,417
Speaking of #1, I also like to see the anodization sanded off until bare metal shows. Here they are just scuffed:
That grounding post is implemented incorrectly. At the bottom of the post there should be a nut with a 'toothed' star washer underneath it to cut through any anodizing or surface finish. Then there should be—in this order—'toothed' star washer, circular lug, 'toothed' star washer, nut. The 'toothed' star washers cut throught any oxide or coating and when properly sized, create a low resistance, solid, gas-tight joint to the chassis, ground lug, and wire.
