Buckeye Amps: Purifi Mono, 2ch, and 3ch Official Thread
goryu
Ah, ok, thought they were going to be a standard feature. Thanks.
Rottmannash
Nashville
Are you gonna send one to @amirm for review and measurements?
Rottmannash
Nashville
If it measures as I suspect, I will order a 3 channel Purifi and relegate my VTV Purifi to a secondary system. Love the added features you're offering, including gain and clipping indicators. Great work!
bkdc
I'm looking for Stereo Purifi amps. No need for heat sinks. The Purifi design runs amazingly cool. My P452 never gets warm in it's aluminum case. The NC502MP generates quite a bit more heat so I can see the value heat sinks might add there with long hours of use. But if Buckeye is trying to keep cost down on the Purifi build - heat sinks will increase prices and may not make much of a difference with a stereo Purifi design.
If Buckeye decides to build 1ET7040SA amplifiers, I think heat sinks will be required for anyone that dares to need 500+ watts. Power output at 2 ohms load on the 1ET400a and the 1ET7040sa is essentially thermally limited. The new Apollon PET 950 1ET7040SA module amps are designed properly with heat sinks on the power supplies and the Purifi amplifier modules attached to heat sink fins on the side of the chassis. I know a custom chassis takes investment and the wiring is impeccable but the price/markup is incredible. I would love to see a budget option with well-designed heatsinks for the Purifis.
Billy Budapest
Suggestion for special edition case color—champagne faceplate, like Conrad-Johnson, Accuphase, and some Sony ES gear.
Matias
São Paulo, Brazil
Billy Budapest
dragonist2
A properly wired RCA to XLR cable is not all that is needed if one wants to use the full output capabilities of the 1ET400A when using dual single-channel opamps like the OPA1612. According to the 1ET400A's spec sheet, 11.2Vpk-pk (I'm assuming pk-pk even though the spec sheet doesn't specify pk-pk or RMS as 12Vrms input would be ludicrous) referenced from the negative input is the max voltage needed to reach full rated power. That's 11.2V / 4Vrms (XLR line level) / 0.707 (RMS to pk-pk conversion) = 3.96 times XLR line level. In comparison, the single-ended max recommended voltage rating, according to the spec sheet, is 5V. That's 5V / 2Vrms (RCA line level) / 0.707 = 3.54 times RCA line level. That would mean RCA users would never be able to reach the full power rating. It would be trivial to use a differential opamp like the LME49724 (used in the Schiit Magnius, a highly rated amp) instead of the OP1612 which will allow proper differential output with only a single-ended input.
Would something like the March Audio p262 that has both XLR and RCA inputs but still uses the OP1612 be a solution for the issue you describe? Or does it come down to the opamp itself and not implementation?
Sidebar: Sorry to derail, I am not suggesting any changes to the current product. Just curious as to the engineering behind this post.
kgt
The debugging/testing on the 2ch Purifi Input Buffer Board is complete and a prototype build is being sent out for measurements (not to Amir but a 3rd party to diagnose any issues before a final production unit).
I can confirm the Purifi board allows both clipping indication and error state indication, which from what I have been told is something most other Purifi builds out there do not offer.
@Buckeye Amps
So, I assume the 3rd party measurements are done and now final production unit is being built? And next step is to send the final production unit to Amir to review?
Keened
Either in this thread or their HyperX thread the go through the reasoning. IIRC it comes down to they are getting a custom input buffer designed by a fellow board member at a very reasonable rate and trying to add RCA would add costs both in terms of parts and design.
They did confirm that a properly terminated RCA -> XLR will work and they have multiple gain settings to compensate.
Buckeye Amps
Buckeye Amps
@Buckeye Amps
A revision had to be made to the prototype board, so as soon as the new one is in my hands it will be sent out for 3rd party measurements
goryu
Weren't you going to use Neurochrome buffer boards at one point? What happened to that?
Buckeye Amps
Buckeye Amps
A member here reached out as they do microelectronics design/fabrication and helped me make all the new boards I am using for my Purifi and Hypex lineup.
It has allowed me to offer some features on the Purifi not many have.
goryu
have you tested the buffer boards to see how they spec out?
